noise when accelerating ( clunk someting )
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Flying White Dutchman, Aug 17, 2012.
  1. Flying White Dutchman
    4,374
    313
    anybody got this to? or now what it is?
    to me its sounds something in the transmission? no rattling but maybe someting moving more then it supose to.?
  2. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
    I don't hear any clunking sounds in that, sounded more like the audio cut out a few times. Do you have any warning lights?
  3. Flying White Dutchman
    4,374
    313
    clunk is just my discription do you know what clunk needs to sound like?
    anyway at the beginning i have gained the audoi 2 times where this " clunk" is .
    after that i did not do this because i hoped it was clear
    also i cut the parts inbetween zo you dont have to lisen to a long drive and taken out the "clunk" moments
    its only when i stop and drive off again and something when i brake also.
    to me it sounds like its from the transmission
    if i would have warning messages then i would have know there is really something wrong
    i personally thing there is a littlebit more movement in the transmission then is normal.
    i also put a link uit to lucsious garage... hope that they responde . with al they know they maybe have some info about it.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Check your CV joints. One may be warn? H
  5. KJP
    KJP Junior Member
    Rochester, ny
    Did you ever figure out what the clunking noise was Flying White Dutchman?
