2011 Prius ATF Drain and Fill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by calirider, Jun 5, 2015.
  1. southtxprius
    southtxprius Junior Member
    78
    South TX
    I've never had the ATF fluid changed. Bought the car used in 2012 with 48K on the ODO. Nearing 87K now. Planning a road trip. Is it risky to change the AFT fluid before the road trip? I thought I read this somewhere on Priuschat to wait...
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    No risk...as long as the mechanic doesn't leave a plug loose. Your car will love you.
  3. calirider
    calirider ECOmobile
    105
    33
    California Central Valley
    I can not see any risk in it. It's super easy and you will get better MPG's with fresh fluid in there.
  4. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    A 10mm allen socket to loosen the drain & fill plugs. Ideally a torque wrench to tighten them(29ft-lbs). And I used a funnel with extension tube to add the fresh ATF.
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    A short ratchet extension helps reach the drain plug. A breaker bar, good floor jack, jackstands. Washers for the fill and drain plugs.
  6. calirider
    calirider ECOmobile
    105
    33
    I thought this video was helpful. The only thing I did different was use a couple foot long tube attached to a funnel rather than a oil pump.
    sfv41901 likes this.
  7. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Thanks for all of the tool info!
    I like the idea of using a long tube and funnel instead of what seems to be problem-prone fluid pumps.
    What is a good length for the tube, and what size diameter?
  8. calirider
    calirider ECOmobile
    105
    33
    Mine is a little over 3 feet long and 5/8" outside diameter and it is perfect. You can't go any larger than 5/8" outside diameter or it won't fit in the fill hole.
    Spindifferent and CR94 like this.
  9. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    the hardest parts are getting the car simultanously level, getting it safely high enough, and removing the cumbersome undershield. Once all that's done, the actual fluid change is a piece of cake.
  10. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    That seems easy enough if you have a level garage floor.
    For the front tires use a pair of ramps for elevation, support & lateral leveling. Then use a jack at the rear jacking point & measure the distance between the floor & the pinch weld in front. Continue to raise the rear of the car until the rearward pinch weld is at the same distance from the floor as the front pinch weld.
    Then it's safely level & high enough.
  11. Spindifferent
    155
    79
    Central Texas
    Much thanks, appreciate the info!
  12. southtxprius
    78
    South TX
  13. Mendel Leisk
    38,219
    ^ those MIGHT work, but the ball head is not optimum. Stanley ( for one) makes a set with straight sides, that would be better.
  14. southtxprius
    78
    South TX
    Thanks. I may try going to the dealer for this, as I don't own jack stands, etc. How long does the drain & refill usually take? I want to make sure I get charged accurately for the labor. I will also take the repair manual pdf excerpt I found on this forum in case I get confused looks at the dealer, lol!
  15. calirider
    calirider ECOmobile
    105
    33
    It took me less than 2 hours but I bet I could do it next time in 1. Removing and reinstalling the plastic undercarriage is the biggest pain. I'm also not a fan of the ball head hex sockets.
    Only other advise I would say is make sure to remove the fill plug first. Because if you can't get it removed after the drain plug your in trouble.
  16. xliderider
    7,848
    3,102
    Honolulu, HI
  17. Boston Jim
    Boston Jim Active Member
    202
    148
    I talked to my dealer this morning asking how much it would be to change the ATF fluid and he said about $400 (really???), everything is electronic now and takes a few hours. Maybe he was talking about flushing the whole system rather than a drain and fill. Um, ok thanks but no thanks.
    But he did say it should be good for the life of the car for the most part, but if you do want to change it, change it before 60k and keep changing it every 30-50k.
  18. xliderider
    7,848
    3,102
    Honolulu, HI
    They always misquote for the service based on a conventional automatic transmission. The Prius transaxle fluid is a simple drain and fill.
    #38 xliderider, Aug 4, 2015
  19. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
  20. calirider
    calirider ECOmobile
    105
    33
    That's why they're called stealerships.
    Boston Jim and southtxprius like this.
