Sugestions for new struts/shocks
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wurzberger, Aug 26, 2015.
  1. Wurzberger
    Wurzberger Junior Member
    Im looking at replacing the struts and shocks in my 04 Prius. Last time I replaced them with some cheap KYBs I found on autopartswarehouse. I was hoping for an improvement over the old warn out parts, but didnt feel an improvement. Well after 5+ years and who knows how many miles I figured it was time to replace them again.
    Does anyone have any recommendations?
    Im not seeing too many options (KYB, Monroe, and Gabriel) and couldn't find anyone making suggestions via google search.
  2. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    Major strut manufactures suggest 5year/50,000 mile replacement i terval, to maintain optimumhandling & braking characteristics.
    You might be able to utilize the lifetime warranty of the KYBs. Read the details, exclusions, and how to make a claim from KYB.
    AVOID the cheap Sensen and Unity struts. Price is attractive, and its a complete assembly. The age old addage of "you get what you pay for," still holds true more often than not.
  3. dat2109
    dat2109 Junior Member
    26
    Carolinas
    Looks like the highest quality drop in replacements for you car would be the SACHS (also branded BOGE) shocks and struts made by ZF.
    Front Left: 312 870
    Front Right: 312 869
    Rear: 912 929
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Make sure you buy new steering bearing with your struts. The top mounts. I only had 60,000 miles on my car when it started to make this low rumbling noise
    like a low frequency booming noise that turned out to be the front struts. The car felt very ponderous into turns also. Like it had alot of weight in the car.
    I never realized how much the steering had deteriorated until I put new struts and bearings on. The steering felt 100% easier when turning
    into corners after new mounts and the car felt light on its feet again. Huge difference. The stock struts are crap and don't last long at all.
    It its your only car and its all you drive you will never notice how bad its gotten.Its hard on the steering rack also. So new bearings will extend the life of the rack to so good investment.
    So...make sure you buy new bearings and all new spacers and boots too. I used various online Toyota oem dealers and bought every part needed then had a tire store install them for me and a front end alignment. I bought KYB's also.
    Car feels new again.
    Fubar1764 likes this.
  5. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Ed, I'm in the market was well for a new set of struts. Would you mind giving me a laundry list of OEM parts I need? And a couple of other questions:
    1) My Prius is one step below Touring. Should I get the Touring struts?
    2) Are there better aftermarket struts you would recommend? I'm not terribly concerned about cost as I'm going to drive the Prius until the doors fall off. Most of all, I'm interested in improving the handling of the Prius.
    Thanks!
    Cheers!
    Jack
  6. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Just go to any online Toyota parts and put your car in and a diagram of the shock and all its parts comes up. There's 2 trims Touring and base. I used kyboutlet.com for the front struts and bearings themselves. I think it was $900 including front end alignment complete front and rear installed. $500 for front & $400 for rear.
    If your keeping the car change the trans fluid and engine and inverter coolant too.
  7. exstudent
    2,212
    900
    Torrance, CA
    Many here seem to go w/ KYB; they are the OEM manufacture for our Prius. Some don't like Monroe. I haven't read of anyone using Gabriel. I know KYB and Monroe all offer "Limited Lifetime Warranty." Ultimately your car & $.
    My post #1 has the parts diagram of front and rear suspension. Post #13 has the description of the parts I ultimately got, and the prices I paid in 8-2014; I would encourage you to get these same parts to ensure no issues. Additional Front/Rear Strut Replacement Parts Needed Too? | PriusChat
    To UPGRADE to Touring, you will need Touring anti-sway bars (front & rear) and the rear assembly (shocks and springs).Here's one posting of a upgrade change out from Base to TOURING.
    Upgraded to "Touring" Suspension | PriusChat
  8. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Great! Thanks guys!
  9. douglasjre
    douglasjre Senior Member
    1,773
    617
    Orlando, FL
    I have KYB excel G's in one car and I'm putting sachs in the other one. It'll be interesting to compare the two cars
  10. Samuraidog
    Samuraidog Junior Member
    51
    Detroit, MI
    Do you have any updates? I'd be curious how you like the KYB excel G.
