Subwoofers?
Discussion in 'Prius c Audio and Electronics' started by Ali T, Aug 10, 2015.
  1. Ali T
    Ali T New Member
    2014 Prius c
    I have a C one and I was thinking about putting in subs... Any advise?
  2. rogan
    rogan Junior Member
    Auckland, New Zealand
    Subs. Buy 1 good sub, not 2 average ones. Less weight, more trunk space; there's no real benefit to multiple subs unless you are doing it for looks.
  3. Zuko89
    Zuko89 Junior Member
    34
    Holland
    Im building a enclosure in the place of the spare tire
  4. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    I have a 8 inch bazooka tube strapped to the back of the rear seat through the child seat anchors. Thumps good enough for me.
  5. ncases
    ncases Senior Member
    609
    672
    Chicago
    OldNo7 likes this.
  6. Zuko89
    34
    Holland
    Poorted B2 audio sub 1000rms 1 ohm.
    2 ft3 /56 liter, and no lost of Space.
  7. Motov8r
    Motov8r Member
    102
    Alpine sws-10 sealed box running 600w. Wired with a quick disconnect when I need to maximize space.
    iPhone ?
    SamanthaC0716, mrpinkie and OldNo7 like this.
  8. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Anyone had luck fitting one under the seat? I am thinking about relocating jack to trunk. Foam has to go for sure.
    Great idea with PVC piping BTW
  9. Zuko89
    34
    Holland
    You got enough Space under the seat?
  10. cyclopathic
    3,292
    547
    2014 Prius c
    That's a good question. I was looking for something like this:
  11. Zuko89
    34
    Holland
    You want a little more base but not heavy low base?
  12. cyclopathic
    3,292
    547
    2014 Prius c
    I am "give me flat" type. Just looking for something to help Pioneer TS-A at the bottom. They are rated down to 34Hz, but this is with 6-8-10dB threshold. Also don't wanna spend too much time soundproofing
  13. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
  14. Motov8r
    Motov8r Member
    102
    I put a sound ordinance 8 in a tundra it worked pretty well and pretty slim.
    iPhone ?
  15. cyclopathic
    3,292
    547
    2014 Prius c
  16. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    Bazooka tube Velcro strapped to back of seat with banana clips for easy removal should I need to. 640 watt 5 Channel soundstream amp under passenger seat. Blaupunkts up front, jbl 3 ways in rear. It may not be a high tier sound system, but I am pleased and it thumps enough to vibrate the seats and rearview.
  17. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
  18. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
  19. randy8876
    randy8876 Junior Member
    44
    17
    seattle, wa
    2015 Prius c
    Keep your hatch area. Keep your spare. 20150824_134021.jpg One good ten does the trick.
    OldNo7 and cyclopathic like this.
  20. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    So…. Ya gonna share under the mat? Lol
