Sezy's Gen 2 custom Cold Air Intake
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sezy, Oct 5, 2015.
  1. Sezy
    Sezy Active Member
    427
    225
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Was able to snag an extra air box from this Prius at a junk yard.
    First make large cuts to remove the MAF housing and the extra tube that connects to the OEM air hose. The MAF is oddly shaped and would not allow for anything else to clamp onto it. The air intake side part will be used to fix this issue.
    I took a torch the the ends of the MAF and extra part then with a flat head screw driver started molding/pulling the melted plastic. Make sure there are no air holes or leaks. I would heat it ,mold a little then cool it off in water until I got the desired result. Used a dremel inside after wards to smooth out the inside and grinded the outside to get any plastic clumps off.
    Some of the parts I ordered. Only thing missing is a small cone air filer.
    First parts to arrive. 2" to 2.25" elbow fits fine.
    Filter came in next. Had to remove the hood insulator for this to fit. Waiting on the tubing to come in. Sounds meaner already.
    Tubes came in so time to try some test fits.
    20150927_142801.jpg 20150927_142811.jpg 20150927_142819.jpg 20150927_143939.jpg
    Looked like it was going to be as easy as a 90 silicon coupler and a long tube with a 45 bend. I was concerned it was folding the coupler too much reducing air flow. That was the least of my worries after I heard a CRUNCH CRACK from my MAF housing part I made.
    Snapped right where I joined the two parts.
    Off to find a fabricator but since I'm cheap I went to exhaust repair shops first.
    Found a exhaust tube that fit in well enough then had the guy bump out the end.
    Goes down far enough it has some lip to grab.
    Grinded it down so I can wedge it down futher into the plastic MAF housing.
    Covered in epoxy then painted to match.
    20151001_170400.jpg 20151001_170409.jpg 20151001_170418.jpg 20151001_170434.jpg
    Decided to cut the whole area out to allow for more wiggle room. Wrapped the intake in duct tape then a old rubber coupler around the area I cut. Zip tied, wire and pipe taped it down, would rattle if I didn't. If you can get the intake tube in nice and neat then right on.
    The intake tube was banging against what I guess is a metal coolant line so wrapped that area in Gorilla tape
    Zip tied the tube to the mount for that metal tube.
    Here is some info Tech Stream gave me when I did a quick high way run with the cold air intake in. At about 90MPH there was a 5 Nm gain in torque over the stock intake so yay but sadly the over all torque decreased. Again according to TechStream so not sure how accurate it is.
    OEM intake run
    Cold Air Intake run
    Wonder what Dyno results would show. We'll see if this helps at the races. More testing results will be added.
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Are you worried about sucking in water? Not good for your engine; water is not compressible.
    JeffD
    Sezy likes this.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    that steel line is an a/c line. definitely don't want it to rub on that.
    as long as the filter doesn't hang below the bumper and he doesn't drive through a creek, no problem. I've had my cone filter under the rh headlight for years.
    Justdidit, Sezy and Daves09prius like this.
  4. Sezy
    Sezy Active Member
    427
    225
    37
    2020 Prius Prime
    Would you say my setup is ok with that line or should I cover/protect it better?
  5. 69shovlhed
    2,170
    744
    Delaware
    I'd have to see it to say for sure, but the main thing to me is to make sure the cai tube doesn't touch the a/c line at all.
  6. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Looking good! Let us know how it performs! That TechStream data is also very interesting.
  7. Sezy
    Sezy Active Member
    427
    225
    37
    2020 Prius Prime
    69shovlhed made a good point so I adjusted the tubes more to the front and zip tied them. Not touching the AC line at all now. Still no Check Engine Light :)
    toyotechwv and Justdidit like this.
  8. Sezy
    Sezy Active Member
    427
    225
    37
    2020 Prius Prime
    Added a heat shield/splash guard. Since lowering the car I've had to mess with the wheel well cover due to rolling fenders and figure i'll add some more splash protection. Probably not needed but makes me feel better about water coming in via the wheel well, if ever.
    Justdidit likes this.
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    708
    75
    Carrollton, Texas
    Four Touring
    Sezy likes this.
