TRD lowering springs - Need a shop in Sacramento
Discussion in 'Gen 3 Prius Main Forum' started by Nes Smith, Oct 13, 2015.
  1. Nes Smith
    Nes Smith Junior Member
    Sacramento
    Does anyone know a shop in Sacramento where I can get my TRD springs installed without costing me an arm and a leg? Any info would help.
    iPhone ?
  2. Gee3
    Gee3 Junior Member
    Any competent shop should be able to install springs easily. The install isn't any different from any other spring install that I know of. Just call around and see what shops charge and if they'll warranty the labor since they can't warranty the part since you didn't buy it from them.
  3. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Spring replacement are straight forward any shop be able to do it! I did my own under 2 hrs, rear are easy took less than 15 mins. Labor for Front spring should be no more that 1.6 hrs, rears 0.5 hrs cost for aligment if required camber bolt kit and labor?
