Featured 2016 RAV4 Hybrid Prices/Spec (incl. Towing)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Nov 7, 2015.
  1. hill
    8,275
    Presuming you're a pv owner for example - you'd actually be picking up 29mpg driving on electricity. Still, nothing wrong with burning a little gas if you have to though
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  3. dipper
    dipper Senior Member
    1,242
    252
    Did some light reading tonight. Found out Subaru is working on the next Crosstrek with Toyota for a plugin hybrid for MY 2018 release. Either Toyota will not have a plugin hybrid Rav in 2018 MY, or this hybrid will be obsolete very soon (like what the Volt ad says).
    If I was sitting on a decision, that news might not be what I want to hear.
    #43 dipper, Jan 1, 2016
  4. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    Obsolete? No, just due for a generational update.
    Jeff N likes this.
  5. Tideland Prius
    16,206
    The Crosstrek is a bit smaller in size than the RAV4.
    sdtundra likes this.
  6. nagrath
    nagrath Member
    139
    43
    Putnam County, New York
    2023 Prius Prime
    XSE
    Good luck getting anywhere near that IRL - I know two CX5 owners and they get much closer to 21/26. Pretty car, though.
  7. dipper
    1,242
    252
    Too bad the US version took the idle ICE and i-eloop off their Euro version. That would have been sweet.
    merged
    Are you saying there is a PHEV SUV in the pipe for Toyota? Toyota is all Fuel Cell, hater of plugin... at least that is what they are telling the public.
    #47 dipper, Jan 5, 2016
  8. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I see lots of them here on the road, mostly driving almost as fast as the Prius drivers, meaning 75mph plus. There's one where I drive to work, fairly plane Jane model. This woman commutes about 20 miles each way, drives no more than 70 on the interstate, not a lead foot anywhere. Since October, her mileage has been averaging 27 or so, pretty much the midline. Her best was a 31 mpg jaunt on all highway. A dramatic difference in driving though. The CX5 is a very fun drive.
  9. john1701a
    12,761
    5,247
    57
    Overlooking the obvious... that RAV4 is due for an update anyway... shows how effective the greenwashing campaigns have been.
    Toyota got labeled as an "all Fuel Cell, hater of plugin" by those greenwashers. Their most common technique was to post information out of context. Simply limiting perspective is an easy way to mislead.
    For example, when the first-gen PHV model production came to an end, they claimed the entire PHV program had been ceased, that support for plugging in had been abandoned. They were relentless too, continuing to make that assertion without any data to actually support it. The fact that Toyota didn't want to get stuck with inventory that would have to be marked down when the next-gen Prius was revealed was outright dismissed. They just kept on with greenwashing efforts.
    Another example is Toyota's effort to diversify. We all know that EV won't work for everyone. We also know that the oil industry will wag a massive campaign against them. To portray Toyota as a fuel-cell only supporter, the greenwashers did everything they could to suppress plug-in endorsements by changing the topic to fuel-cells. That desperation to mislead about intent was amazing. They were relentless.
    We've seen quite a bit of that in the past too. But there's no need to look back any further than 2015. Some have went to great extremes to build up false impressions... so effective, overlooking the obvious becomes common.
    In this case, we know Toyota is expanding hybrid offerings to every passenger model vehicle they produce by 2020. The hope of eventually being able to provide a package-option choice with a plug should be obvious. Gen-2 PHV is helping pave the way, just like the original Prius did for expansion to other models over a decade ago.
    bwilson4web likes this.
  10. arescec
    arescec Active Member
    238
    105
    Croatia
    What's all the fuss with the 4WD, don't they have paved roads over there in the US or it's just that Americans like going off road that much :D?
  11. Trollbait
    11,674
    It's more people worried about snow and ice on roads. Considering the state of funding for snow removal and salt in some areas, it can be a legitimate concern.
  12. austingreen
    austingreen Senior Member
    13,593
    4,132
    Austin, TX, USA
    Roads are in much worse condition than they are in germany. In general they are better than some european countries. YMMV. In texas where I live, we normally need to go on a dirt or gravel road to get to camping or hunting areas. If it has rained heavily awd definitely helps, but you can avoid them during those bad condition times. We have a lot of snowy places and mountains that you need chains or awd to negotiate. Typically if you are buying a SUV like rav4, you either are a never never (never tows never goes off road) that doesn't need it, or awd is an important option.
    Japan buys awd even more than the US. Subaru is a popular vehicle for the snowy/rainy awd in US.
    From a design point of view, given the economics, I would only design hybrid or PHEV SUVs as eAWD. Once you have the hybrid drivetrain it is a lot less expensive to add eAWD than a mechanical one, so forcing the option makes it look like a much lower hybrid premium. MG2 could be down sized if you know there is going to be an MG3, and toyota doesn't seem to trust towing without a fwd hsd.
  13. bwilson4web
    15,584
    A Prius towing a caravan just might be the trigger for apoplexy:
    telmo744 likes this.
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
  15. mikefocke
    3,729
    1,665
    Sanford, NC
    Boy can it get pricey when you configure one fully.
    No spare tire I presume.
    Loses about 8 MPG to the v.
    Review did not speak of any noise issues which would be a plus.
    Anyone seen one?
  16. ny_rob
    1,968
    813
    L.I.- NY
    #56 ny_rob, Jan 15, 2016
  17. dipper
    1,242
    252
    Anyone seen the new Rav4 hybrid commercial with the wolves? I am surprised that it was allowed to air with the part of the guy nursing the pups. It's the way they made it was R rated comedy.
    Just wondering if anyone noticed?
  18. bisco
    49,796
    completely unnecessary in civilized areas of the u.s.
  19. wolfe
    wolfe New Member
    Nevada
    37.1 mpg after driving 70 miles on freeway at about 75 mph and 10 miles on local roads at 45 mph, not bad huh?
  20. Tideland Prius
    16,206
    wow, impressive.
