how to remove front door panel and replace side view mirror (Prius C 2014)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by christro, Aug 6, 2015.
  1. christro
    christro New Member
    Utah
    2014 Prius c
    I've searched but haven't found any videos, images, or instructions on how to remove the door panel on a Prius C 2014 in order to replace a side view mirror. Has anyone done this? I've done it on my Toyota Corolla but with a you.tube intructional video. Thanks.
  2. barbaram
    barbaram Active Member
    911
    70
    Trenton, NJ
    Any answers on this? I just demolished my passenger side mirror so I might need to know... Thanks!
  3. jZerbe0011
    jZerbe0011 Junior Member
    Lancaster, PA
    1. Pry open screw cover inside door latch hole and remove screw.
    2. Remove window and door lock switch panel. (I pryed it out with a puddy knife) Remove wires from bottom.
    3.Remove the 2 screws in the hole you just opened up.
    4.Reach down towards where the speaker is in the door panel and grab ahold of the door panel and pull firmly. Continue to do this the whole way around the panel, when all plastic clips are free, lift the panel up and away from the door.
    5. To reinstall the panel you have to remove all the white plastic clips from the metal side of the door and slide them back into position on the plastic door panel. And then line them up and punch the door back into place.
    Hope this was helpful!
    Mo G likes this.
