  1. Princedunet
    Princedunet Junior Member
    46
    morocco
    2012 Aqua
    Hi guys..
    I read about the white smoke and I found that is normal in cold weither!! Is that true and what do you think ?
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    If it's just water vapor condensing in the cold air, then yes, it's completely normal.
    CR94 likes this.
  3. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    Depends on how you define "cold weather".
    If you are talking about when first start the car, then yes, it is normal.
    Maybe where it snows or near freezing temperatures, it is normal, but in California, there is something wrong.
    iPhone ?
  4. Former Member 68813
    3,524
    981
    US
    i would not call it smoke in the first place, but it could be just me.
  5. Dion Kraft
    Dion Kraft Member
    272
    79
    Washington, UT
    The white smoke is normal in the mornings till the engine is completely warmed up - what if it continues and never stops....now thats another problem.
  6. Princedunet
    46
    morocco
    2012 Aqua
    thanks everybody, but it happend just sometime when it's cold
  7. ETC(SS)
    6,493
    The same kind of white "smoke" came out of my mouth this morning when I went to work.
    I'm not normal, but the vapor is....at least when it's cold enough outside. :D
    KrPtNk and bisco like this.
  8. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    It's water vapor, not smoke...
  9. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    That's not water vapor. It's condensation, i.e., fog, from water vapor.
  10. RRxing
    2,518
    1,790
    NEPA
    Correct... I was in a hurry... ;)
    CR94 likes this.
  11. Princedunet
    46
    morocco
    2012 Aqua
    Yes guys, it a water vapor, i touch the smoke with my hands and they become wet
  12. bisco
    48,962
    like the stuff coming out of the manholes?
  13. qdllc
    qdllc Senior Member
    1,358
    396
    When white vapor comes out of my man hole it's most definitely NOT water. :LOL:
