Tranny fluid change
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by randomwalk101, Apr 23, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    268
    texas
    since there isn't a dipstick to measure transmission fluid level, how do we know of its low/normal/high etc?
    Anyone has a drain & fill transmission fluid procedure for the 16 Prius?
  2. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    See no love for this neglected thread/lol
    Good question BTW
    #2 ETP, Apr 23, 2016
  3. bisco
    48,945
    it's never been a problem iirc, hopefully, fluid changes are as ease as removing the fill and drain plugs on past gens. remove the fill plug first, in case you can't get the drain plug out. fill until fluid begins to seep out over bottom of hole threads.
  4. randomwalk101
    532
    268
    texas
    Thank you for your reply. I searched the board and also googled instructions how to change transmission fluid for the Prius (at least previous models). The instruction of how to change is exactly as you mentioned. That is crazy simple compared to my previous truck (Toyota Tundra). On the Tundra, there is a drain plug, fill plug and a fluid level plug. Also, the transmission fluid needs to be at a certain temperature when it levels so make it a lot more complicated.
    If the new Prius is simply drain and fill until fluid drips out of the fill plug at room temperature than that's cake walk.
    I am attaching the Tundra transmission fluid fill procedure just for kicks....BTW, do you guys know how to obtain something like this from Toyota for the Prius?
  5. bisco
    48,945
    i imagine you have to subscribe to toyotatechinfo for $15. and download what you need.
  6. randomwalk101
    532
    268
    texas
    Also, it'll be tricky to lift up the Prius to change the transmission fluid while keeping it leveled without a lift. With my previous truck, no lifting needed..I just crawled down and go to town with it..LOL...
  7. bisco
    48,945
    yes, that's the hardest part. almost worth it if you can find someone to do it for a hundred bucks.
  8. Mendel Leisk
    38,207
    I'd assume it's very similar to third generation. Description of that follows:
    There is no dipstick, but you can rest assured that if the fluid level was right to begin with, and there's no leakage, it's still right.
    There's a fill and drain bolt, with washers that should be replaced, relatively cheap insurance. Both bolts have a 10 mm hexagonal pocket, requiring a corresponding male driver for remove/install. Torque for both is 29 lb/ft.
    Purchase 4 quarts (or liters) of Toyota ATF-WS in advance, you'll need roughly 3.5. The simplest method to get the fluid is via a funnel above with a 3 foot tube extension. Keep the tube OD 5/8" or less and it should fit ok.
    Raise the car and level it. For a DIY'r it's not that hard. What I do is raise the front, support on jackstands, then repeat at the rear. The aim is to raise the car enough for access and to get it roughly level.
    Remove the fill bolt first, just to ensure no problems, then position a drain pan and remove the drain bolt. Reinstall and torque the drain bolt with new washer, and add fluid through the fill hole, till it starts coming out. This sets the correct level. Reinstall and torque the fill bolt with new washer.
    thatoneraccoon likes this.
  9. bisco
    48,945
    changing the fluid is the easy part. the rest makes me drop it off at my local gas station.
    ETP likes this.
  10. Mendel Leisk
    38,207
    I'm getting to that mind set, especially regarding getting up on my roof. But getting under a car I'm still ok, just work methodically, and always put something non-compressible and thicker than me under, first. And carry a cell phone, lol.
    ETP and bisco like this.
  11. bisco
    48,945
    yep, the gutter cleaning is going to be outsourced in the near future.:p
    i wouldn't mind crawling under the car, but getting it up on jacks and level just sounds like too much effort. if the local guy will do it for $60. labor, i'm cool with that.
    ETP and Mendel Leisk like this.
  12. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    I'm the same way. I'm not getting under my car supported only by jacks anymore. Just me. I will drive the front end up on ramps and support the rear with jacks, that way the area I am working in is on its own wheels. I don't go on the roofs anymore, and I won't climb into an attic without a proper latter. Too many of my friends have had to change their careers/jobs due to at home injuries that could have been prevented. Once you injure your back, neck, collar bone or shoulders, fewer companies want to risk hiring you!! Plus if you have a good paying job that requires you to be able to use your body, it pays to keep that body in one piece. One guy I know was cleaning his rain gutter (had been doing it for years) lost his balance, fell, broke his collar bone, arm and leg. Out of work for nearly 2 years. Rehab was the worse. Lots of loss of income. Total life changer. I use him as my "no brainer" reminder.
  13. cipsaz187
    cipsaz187 Member
    147
    42
    Maybe you're asking too much from a new car. Just sit and drive for now. Worry about the tranny fluid a bit later.
    ETP likes this.
  14. ETP
    2,799
    1,170
    Auburdale FL
    Maybe trade it at 125K. Beginning to wonder if that is the best option.
  15. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    I've always believed that it's best to keep a car for a decade or more, and 250k+ miles. That was my plan when I bought my 2010. Instead, I kept it for 6 years and 130k miles.
    Those were 130k absolutely trouble free miles. Could it go more? perhaps. But there is a lot of expensive technology on that car, and if anything does go, it will not be a small bill. I got lucky on the 2010. I'd have loved to keep it another 5 years, and get up to 250k miles, but I'm happier knowing that (at least for the next 3 years) there won't be any surprise repair bills. (Not that this didn't come for a price...)
    ETP likes this.
  16. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Remember, change the transaxle's ATF WS fluid using some routine: every 60,000 miles, every 100,000 miles or my favorite: 30,000 miles then 90,000 miles then every 90,000 miles.
    And NEVER change a tranny's fluid unless asked, they have privacy rights, too.
    ETP likes this.
