Cabin air filter
Discussion in 'Gen 3 Prius Main Forum' started by Manhal K Alrashdan, Apr 28, 2016.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    jordan
    I have removed my cabin air filter and found very dirty and full with carbon residues from the bottom .can I wash it with water or just by air blower ?
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    It needs to be replaced
    Okinawa likes this.
  3. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Some cabin air filters are impregnated with activated charcoal to help absorb odors. That's probably what you are seeing. ;)
    Manhal K Alrashdan likes this.
  4. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Yeah, I just had mine replaced at my last service. That and the engine air filter
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    As Xliderider stated, the filter is charcoal impregnated. If the top side is still relatively white, you're ok. If it's dinghy gray then it's probably due for replacement. Look in the top folds for excessive debris as this is also a good indicator of the condition. If you do replace it, go with an OEM or equivalent
  6. Mendel Leisk
    38,220
    You could try blowing air in reverse direction, and a little brushing. It's not as critical as the engine filter. This is one item I slack off on. :)
  7. mrbigh
    3,686
    699
    Long Island, NY
    I keep my wife's air cabin air filter clean once a month. I reverse blow compressed air from the inside out and it worked for us since a long time. It was replaced twice since 2012.
  8. socal13
    socal13 livin in the foothills...
    262
    86
    Altadena CA
  9. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    My local auto parts chain stores sell only the charcoal/activated carbon filters at $ 20 and up.
    To answer the OP's question, the filter isn't made for a water flush and reuse.
    If you want to reuse, then follow the advice above. Shake it out, blow air through it. good to go.
    I'd say just buy a new Toyota oem cabin air filter. Your old one could be clogged and not letting full air flow through.
    #9 Eastside, Apr 28, 2016
  10. Mendel Leisk
    38,220
    Our original cabin filter has gone 60,000 kms, so far. That said I suspect our wet coast weather keeps the dust down, more than other climes. I've blown the dust out of it a couple of times.
    Still on the original engine air filter too. You can just see it's starting to get a little sooty now, but really not bad. The fuel/air mix is computer controlled too, so even when it starts clogging it won't run rich. And it's really got a ways to go.
  11. socal13
    262
    86
    Altadena CA
    fyi... check the manual and change the filters as recommended.
    Cabin air filter:Made to prevent outside allergens and dust from entering your ride’s air vents. The benefit: it keeps the air that you breathe inside the cabin clean. They’re engineered to trap a whole bunch of things, including pollen, dust, mold spores, smoke, soot and smog – none of which belong in your nose.
  12. Kenny94945
    Kenny94945 Active Member
    767
    392
    Sausalito
    2016 Prius v wagon
    There are HEPA filters and charcoal filters and just regular filters.
    Price varies, yet after a few years it is good to replace.
    (The brand Puralotor I believe sells a charcoal for $20 at most parts stores.)
    Yes, you can increase the life of the filter by removing and cleaning it with tapping (to drop dirt off it) gentle air.
    Pollen and diesel particulates still may stick to it.
    Don't forget to clean the filter housing if need be.
    The filter function still doesn't last forever.
    Have fun.
  13. Mendel Leisk
    38,220
    In summer we just shut the vent system down and roll the windows down, most of the time. It's funny, go back 20 years, none of the cars had cabin filters; a lot of this is marketing I think.
  14. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    When you replace or inspect the cabin filter, reach into the filter holder and down. There's a fan which can catch debris which can rattle about. Remove anything you find.
