Does replacing water pump also replace coolant?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kettledrum, May 24, 2016.
  1. kettledrum
    kettledrum Member
    181
    Indianapolis, IN
    This is probably a really dumb question for those of you in the know. Here's the full story.
    I have a 2006 and am at 100k. The maintenance schedule specifies replacing the engine and inverter coolant at this point.
    At 50k I had the water pump replaced under warranty. The job order (see photo below) also shows coolant...
    At some point before that I had T-SB-0087-08 done for the screaming banshee noise coming from the storage pump.
    Did either (or both) of these replace either of the necessary coolants and don't need to be changed now?
  2. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    From what I read on PriusChat, most inverter pumps were changed under warranty without changing the coolant, so you should assume that the inverter loop has never been changed. One gallon of coolant is not enough to change the engine loop, so you should assume that it was never completely changed, even if they used the full gallon.
    The maintenance schedule for Gen 2 calls for the initial change of the coolant at 100K, and subsequent changes at 50K intervals. Since it has been 50K since your last change, both of the systems in your car are due for a change now, even if they were changed when the work was done.
    The logic behind the schedule is that you really can't get all of the old coolant out of the system when you change it. The old coolant that remains in the system reduces the change interval.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    I agree with Robert's statements. Furthermore, others on PC suggest to consider installing another new inverter coolant pump at the coolant change interval as well for additional piece of mind. And while its not necessarily recommended by Toyota nor your dealer (you can guess why) at100K miles would be a good time change your transaxle fluid as well if it hasn't been done recently.
