Prius c Extended Warranty?
Discussion in 'Prius c Main Forum' started by priusmatty, May 24, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Hi all,
    Thanks to your advice, and some research, I have decided to buy a new Prius c Four next month. I have owned new Toyotas before (an Echo and a Yaris), and I have never bought an extended warranty, because I always thought they were wastes of money with Toyotas being so well-engineered. But will a hybrid be different? Did you get an extended warranty? Is it recommended? Thanks!
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I wouldn't waste the money on an extended warranty. The Prius has shown itself to be an extremely reliable vehicle. The 2016 Toyota Prius c has a three-year/36,000-mile warranty and a five-year/60,000-mile power train warranty and hybrid parts are covered by an eight-year/100,000-mile warranty.
  3. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Ok thanks. The hybrid parts are the ones I was worried about, and 8 years is pretty darn good.
  4. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
    Good luck on your purchase.
    Welcome to PriusChat. This site is an excellent source of information as you learn about your Prius and hybrids in general.
  5. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
  6. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    The Prius C is rated as extremely reliable by Consumer Reports in every category. Their ratings are based on surveys they conduct of their readership, and I know of no other source that's as extensive, so I put a fair bit of faith in it. Given that, I wouldn't bother with the extended warranty.
  7. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
  8. IL Traffic Attorney
    IL Traffic Attorney New Member
    Naperville
    I would caution against completely forgoing the warranty. Note your maintenance levels and how consistent you are. So long as you are proactive, you probably can forgo it. If you are a bit lax however, you may want to consider it. Also, warranties do have perks for those unexpectedly annoying problems that can creep up. For example, my car squeaked every time I hit a bump. Thought it was the transmission. Was actually the passenger seat frame which needed parts replaced. Was covered by my warranty.
    While the basic warranty is great for these things, a reasonably diligent driver who keeps on top of their car would have caught these issues long before the factory warranty terminates. Hence, the only benefit I can see of the extended warranty is for situations when you are less than diligent.
