Brake fluid flush with Mini VCI
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andrewclaus, Nov 14, 2015.
  1. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Has anyone here done a brake fluid flush using the Mini VCI? How did it go? Any tips about using the Mini VCI?
    I saw reference in one post to there being nearly a gallon of brake fluid in the system. How much did you use in your flush?
    Thank you in advance.
  2. mark5211
    mark5211 Junior Member
    22
    Houston, Texas
    About to change my brake fluid on my 2008 gen II. I have the same question and I have a mini VCI. Did you find an answer?
  3. andrewclaus
    993
    324
    Golden, CO
    No, I didn't, but went ahead and did it anyway. I found decent enough instructions somewhere online and muddled through it. The MiniVCI part was confusing and I'm not sure I used it right, so I won't give any instructions, but it worked out okay. I used about three quarts to get everything running clear. Two may have been enough. As I remember, you need to get the pump to work to bleed the back brakes, but the fronts will work with traditional means. (As long as you don't get air in the accumulator.) Good luck with yours.
    mark5211 likes this.
  4. mark5211
    22
    Houston, Texas
    Thanks for the reply. It will help. I find the Techstream software a bit confusing and buggy so I'm not surprised by your experience. Thanks again.
  5. andrewclaus
    993
    324
    Golden, CO
    Yeah, it might help if you're a trained Toyota mechanic first. You don't get a comprehensive manual and training academy with a $25 MiniVCI! Running it on the ten-year-old laptop retired to the garage probably doesn't help much, either.
  6. Currahee
    Currahee Member
    103
    33
    CT
    It's covered in detail in the repair manual, but with the "handheld tester" not the Techstream PC interface. I don't know how much they differ. On the other hand, dealers seem to charge less for this service than ostensibly easier things like trans fluid.
