Navigation and Turn List
Discussion in 'Gen 4 Prius Audio and Electronics' started by helmkera, May 23, 2016.
  1. helmkera
    helmkera Junior Member
    51
    Sandwich, Illinois
    In my Prius 2005 BC, I enjoyed having the turn list posted on the right hand side of the nav screen. I noticed on my 2016 Prius Four ATP that all I saw were freeway exit lists and the occasional upcoming turn screen. I opened my trusty "Navigation System Owner's Manual" to page 199 and read about Map Mode. I see clearly that Option 4 is the turn list, but on my screen only the first 3 options are present. Is there some thing else that needs to be selected to have option 4? BTW: this is a US market vehicle.
  2. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    I observed this as well. I think that in order to have Turn List available, you need to have an active Destination...
  3. helmkera
    51
    Sandwich, Illinois
    I just ran a test. I selected a destination and hit GO. Then I checked Map Mode under Options and still only have 3 options. - no turn list. BTW: this map dates to 05-1-2015; I have had the car less than a month and assume that this was the latest software at the time of shipping.
  4. helmkera
    51
    Sandwich, Illinois
    Eric, you were right. It wasn't enough to select a destination and hit GO. Once I started to that destination (a block or so), I could go to Options and select Map Modes. Behold - there was the option for Turn List (on the right side of the Nav screen just like I had in my GEN2 Prius.
    PriUncut and DonD like this.
  5. eric1234
    390
    198
    Hamden, CT
    Oh, good! Glad to hear it - I hadn't had a chance to double check on mine (I don't really like or use the Toyota Nav much - I prefer Waze) - but I was afraid that there might have been a bug in ours...
  6. ATHiker
    ATHiker Senior Member
    642
    560
    Massachusetts
    Four Touring
    For me it comes and goes-- as does the itersection option which looks virtually the same, but with very some minor differences.
    I believe the kind of road you are traveling -- highway vs city street-- comes into play, but beats me how exactly.
    If you ever get all the options to light up, I will be impressed!
  7. MorganAdcock
    MorganAdcock New Member
    upstate New York
    Three Touring
    Sorry about the double post. It appeared that the first attempt hadn't posted.
  8. MorganAdcock
    upstate New York
    Three Touring
    Can you set this and forget it, as in have it come up forever more unless you change the options again?
  9. helmkera
    51
    Sandwich, Illinois
    It appears to "stay set" for future navigation until you reset it.
