no text messages
Discussion in 'Gen 4 Prius Audio and Electronics' started by hcprius, May 30, 2016.
  1. hcprius
    hcprius Junior Member
    59
    Alabama, USA
    The car tells me I have a new message, displays who it is from, and then shows a blank box for the message.
  2. Bill the Engineer
    1,044
    2,272
    467
    At the beach in Delaware...
    Is the car moving when you try to look. That's a no-no.
  3. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    Yes - if the car is moving - your only options are to "Read" (i.e. Pamela will read it to you), or "Ignore", which will close out the dialog box.
    XStine likes this.
  4. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    It would be helpful to know what kind of phone? And how it's connected? Bluetooth? USB pulled in?
  5. XStine
    XStine New Member
    Memphis, Tennessee
    Aha! That makes a lot of sense. Thank you - my blank text messages stymied me, too. My "technology specialist" was not terribly thorough when running me through the features, and I figured I would read the manual later - but haven't gotten around to it yet. I'm still not used to giving voice commands to my car!
  6. nategold
    nategold Member
    117
    Arlington, MA
    I only very occasionally see the read button - perhaps after the system reboots, which it does occasionally. It is usually grayed out. But holding down the Siri button and saying "read new message" works just fine. This is with an iPhone 6S, latest iOS.
  7. nategold
    nategold Member
    117
    Arlington, MA
    I meant holding down the phone button, which kicks in Siri.
  8. XStine
    XStine New Member
    Memphis, Tennessee
    Apparently I can't dictate a text reply, though this is supposed to be a feature. When I try, I'm told that "this function is not available on the connected phone." Is there some trick to this? I just sort of assume that an iPhone 6 is going to be up on the latest tech, but Apple and Toyota have never particularly played well together.
  9. DiKat
    DiKat New Member
    Sunnyvale. CA
    Four Touring
    I am having the same issue with my iPhone. I will have to try this.
  10. DiKat
    DiKat New Member
    Sunnyvale. CA
    Four Touring
