Question about Adaptive Cruise Control in stop-and-go traffic
Discussion in 'Gen 4 Prius Main Forum' started by CalMark, Jun 1, 2016.
  1. CalMark
    CalMark Junior Member
    Palm Springs, California, USA
    Judging by what I've read, it sounds like the adaptive cruise control in the 2016 Prius can take you down to a full stop, but it then disengages immediately. Some cars (like my Volvo) have ACC that remains engaged for three seconds before disengaging. This is highly useful in stop-and-go traffic. It sounds like the Prius does not offer this feature. Am I correct?
    ETP likes this.
  2. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    If you come to a complete stop, you have to hit resume, but that is all.
    ETP and kithmo like this.
  3. jbkendrick
    jbkendrick Active Member
    232
    197
    Baltimore, MD
    I believe Danny noted on his first drive report that you can also just tap the accelerator to resume as well. And the owners manual indicates that drcc will remain set up to 3 minutes at a stop so long as doors stay closed, car remains in drive and drivers seat belt is not removed. J
    #3 jbkendrick, Jun 1, 2016
    ETP, PriUncut and kithmo like this.
  4. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    ACC works perfectly fine in stop and go traffic. It slows with the car in front, and when it stops your car will creep up and stop maybe a little further than I would have stopped. You can hear the brakes go into a "hold mode", and the indicator in the dash will say "waiting".
    I don't think that there is a time limit, but I've never measured it. Besides, whats it going to do after the limit ? Release the brakes...I don't think so.
    I usually use the accelerator to resume, since the car wants to resume it's inter gap distance between you and the car in front, a little too quickly which is something just not done here in New England. So I use the accelerator, and back off the distance from the car in front at the rate I want it to. On bad traffic days on i495, when the stop and go can drive you crazy, I just tap the accelerator and let the car do the work.
    If you want to hear a panic beep, let the ACC bring you to a stop, take you feet away from the pedals, and then turn the cruise control off at the switch. I the cars point of view, Who's in charge ? It keeps the brakes on, and does it's panic beep.
    The only time that the car drops out of cruise control has to do with a car in front of you, leaving the road. It can tell the difference between lane change and leaving the road. Lane changes, result in the car continuing as normal, and a possible acceleration to cruise velocity. When a car turns off the road more than likely, the ACC will turn set off an alarm and then disengage. This only happens if the car was affecting your velocity. I've not completely explored the conditions that it disengages, I suspect that it has different strategies based on (1) velocity (2) the differential between velocity and target velocity (3) distance to the car in front (4) how fast your velocity was decreasing to keep distance.
    I know that I can defeat strategy 4 from disengaging by pushing on the accelerator to keep my velocity the same, but not always, rule 1 may override.
    ETP likes this.
  5. jbkendrick
    232
    197
    Baltimore, MD
    According to page 237 of the owner's manual, cruise control will be deactivated after 3 minutes and the car will be shifted into park.
    The shift position may also automatically switch to P if one of the following
    conditions is detected while the vehicle is stopped by dynamic radar cruise
    control with full-speed range.
    • Driver’s seat belt is not fastened
    • Driver’s door is opened
    • Approximately 3 minutes elapse after the vehicle stopped
    ETP and PriUncut like this.
  6. Gazzy
    Gazzy Junior Member
    Seattle,Wa
    Once car stops, the cruise control doesn't disengage, it goes into a waiting mode. So all you need to do is either move the cruise control lever or tap the gas pedal to start moving again. Way better implementation than on 2015 grand Cherokee that just turns off after 3 seconds of stopping.
    ETP likes this.
  7. ETP
    2,802
    1,170
    Auburdale FL
    You guys have this all geeked out. Nice.:):):):)
  8. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Today I confirmed the drivers seat belt and drivers door reaction of going into park.
    It does it with ample alarm.
    I tried to verify the 3 minutes time out by dcc'ing into my parked pickup truck in my drive way, but my wife caught me and there was no explanation that I could give that could cool her down.
    I'll try later...
  9. ETP
    2,802
    1,170
    Auburdale FL
    Be careful. Tried that in a parking lot and my wife was ready to kill me.
  10. PriUncut
    PriUncut Active Member
    268
    266
    Southern California
    Four Touring
    When in doubt... read the manual. Something I need to do more ;).
    ETP likes this.
  11. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Just because it's in the manual, doesn't mean it's there.
    Trust, but verify
    PriUncut and ETP like this.
  12. ETP
    2,802
    1,170
    Auburdale FL
    Goes for a lot of things in life.
    PriUncut likes this.
  13. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    How can I verify the pedestrian detection system without pissing someone off?
  14. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    From what I understand so far, if your foot is on the pedal, the Prius will run over.
    If not, who knows ?
    #14 I'mJp, Jun 1, 2016
  15. Tideland Prius
    16,206
    So at 60km/h with a pedestrian walking from the left (curbside cause it's the UK), it avoided a collision. With a pedestrian walking from the right, the car hesitates at 45km/h (you can see it lift off the brake momentarily)
  16. PriUncut
    268
    266
    Southern California
    Four Touring
    Ohhhh, that Euro NCAP crash test video is painful to watch. Always makes me un-easy thinking that could happen to my new car... but at least I'll be safe! Very interesting... I've not seen those side tests before.
  17. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    I could have sworn ACC doesn't need any intervention from me in stop go traffic to continue.
    LG-H901 ?
  18. krmcg
    2,592
    2,390
    Whittier, CA
    It does when it comes to a complete stop. Not if it keeps crawling forward.
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    It can crawl real.... slow too.
  20. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Funny to watch the tow hook hole cover come off in the side impact. Must be a very energetic impact, because those things are "welded in" when you want to remove them. ;)
