Tire Pressure - Soup to Nuts
Discussion in 'Videos' started by RRxing, May 26, 2016.
  1. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    Warning! There will be math...
    ETP likes this.
    48,934
    i lost my grip years ago...
    ETP likes this.
  3. ETP
    ETP 2021 Prime(Limit),Highlander HYB Plat,B52-D,G,F,H
    2,799
    1,170
    Auburdale FL
    Still gripe though. Also where is the soup and nuts? Lunch time.
    Side note to the outstanding video: Seems the low RR tires that come on the Prius as OEMs (MIJ)s have a pretty even wear pattern at 42PSI. Suspect tire design and weight of car may be a factor (car may be over tired/LOL). TBD. Also lower pressures (36PSI) seem to wear a tire out quicker. 51 PSI was too much for me in Honda Hybrids as the tires would skip when hitting a bump. Since 2002 I have not worn the center of a tire out on a Hybrid OEM tire. Did do that on conventional vehicles years ago with non Low RR tires.
    Completely baffled why this has happened. It may be wearing a little more in the center but I was never able to see it or crude measure it.
    Defies logic/maybe.
  4. ETP
    2,799
    1,170
    Auburdale FL
    Did notice that non MIJ GY Fuel Max tires on a Dodge Caravan do not wear as well as the MIJ OEMs on the Prius. Even have a bubble on a side wall starting to grow. QA in other than MIJ factories is suspect as always.
    This is the last set of GYs and Michelins for me at SAMS since I have had repeated poor results. May try Bridgestone or Pirelli at SAMS the next time for the Caravan.
    Seems tire rack is the only sure thing and look for MIJ.
    #4 ETP, Jun 27, 2016
  5. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    Video was saying about 4% MPG Loss going from say 35 to 20 psi.
    So let's say from 50 MPG down to 48 MPG.
    But the curve flattens out so going up in pressure from 35 to 50 psia would probably be more like 50 to 51 MPG. I've shown some similar calcs previously.
    ETP likes this.
  6. justinope
    justinope Junior Member
    Tucson, AZ
    Interesting, thanks for posting that
