Safe to drive without plastic cover UNDER engine?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eliteconcept, Jul 25, 2016.
  1. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    448
    186
    Indiana
    2022 Prius Prime
    Would it be ok to drive a few days (given I drive about 100 miles a day) without the plastic protector cover under the engine, the one you have to remove to change coolant, or transaxle fluid?
    I'd think it'd be ok for a few days but I'm not sure entirely of that things purpose though.
    Thanks in advance
  2. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Its safe to do. Just go thru deep water puddles very slowly as not to splash water on engine and short out electrical components. Its just to keep engine dry and contribute to the aerodynamics of vehicle.
  3. eliteconcept
    448
    186
    Indiana
    2022 Prius Prime
    ah ok, we have no rain in forecast, if some shows up on forecast I'll just throw it back on. not worth the risk to save 20 minutes lol
    lar.smith42 likes this.
  4. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    I've cleaned my Prius engine with a garden hose plenty of times. The electrical connections aren't likely to be harmed by water. The danger is sucking water into the engine air intake. But in a Prius, air enters the engine through a long horizontal hose and then into the bottom of a large air cleaner box, so I think it would be almost impossible to suck water into the engine unless the car was under water.
    But with the splash shield gone? I think there's no way you'll get water damage because of that. Just a dirtier engine from grime and dirt getting kicked up there.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    And slightly lower mileage. ;)
  6. Mendel Leisk
    38,213
    ^ This.
    I have pipe insulation sections pushed over the seams at junction between top of fender and hood. These plus the engine under-cover, besides improving engine warm-up, seem to be keeping the engine bay on ours near-new looking.
  7. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    pictures?
  8. Mendel Leisk
    38,213
    Yeah, worth a thousand words.
    (3rd gen pic)
    schmuber, Robert Holt and Raytheeagle like this.
  9. StarCaller
    1,240
    692
    ok, now I see. how high has the foam to be (meaning, what size did you buy?) that would probably help me to keep at least some of the dust out of my engine compartment. here in new mexico dust & sand is/goes EVERYWHERE....
    BION
    StarCaller
  10. Mendel Leisk
    38,213
    It's a common size, OD about 1.5". For 1/2" (nominal) copper plumbing pipe size. The groove along the top is from the hood, just snugs on it.
    Guess you go through the air filters. :(
    StarCaller likes this.
  11. David Beale
    5,963
    1,981
    Edmonton Alberta
    Mendal, I suspect sealing those gaps increases the underhood temps a bit. Not important here in Canada, but in the desert southwest....
    StarCaller and Mendel Leisk like this.
  12. Mendel Leisk
    38,213
    Yeah faster warmup was my object. Then I noticed our engine bay staying quite clean so hey. I did monitor temps with ScanGauge for several years, and never saw overheating, but that's here. Good point, about desert climes.
    Something like a sustained uphill mountain climb too, you might want to pull everything off.
  13. StarCaller
    1,240
    692
    you might be up to something here/
    I didn't think about that/
  14. Mendel Leisk
    38,213
    FWIW, the only time I've seen temps "womp" right up to 90~95C, and stay there, is on our local ski hill. Dragging a ton or two of car up a steep grade for half an hour.
  15. StarCaller
    1,240
    692
    if I drive home from albuquerque it pretty much goes up all the way/
    maybe it's better to leave at least some little gaps for the hot air to escape....?
  16. Mendel Leisk
    38,213
    I've left that insulation (per the pic) in year 'round, right through summer. I do regular grill block much more cautiously. It's debatable, less so if you have some way to monitor temps, for sure. ScanGaugeII?
  17. StarCaller
    1,240
    692
    yep, scangauge is there/
    so I guess the only way to figure that, would be to put the insulation on & see if it makes a difference temperature wise/
    might take me a few days to go to albuquerque to go to lowes or home depot to get some insulation/
    but what I think is that there will be a heat soak under the hood, once the car is shut off/
  18. David Beale
    5,963
    1,981
    Edmonton Alberta
    Well, I wasn't wondering about the coolant temp, but rather the air temp under the hood. I think the coolant temp wouldn't be affected much by those tubes. It's fan controlled and the hot air vents under the car. But after shutoff I suspect -some- hot air normally vents out those slots, narrow though they are. You could be making a convection oven. :) Maybe I'll have to try them too. The hottest we see here is around 30C, but it's the coldest that's of concern - -40C sometimes. ;) My lower grill is blocked all winter and even in the late fall and most of the spring, and I never see high temps or hear the fan roaring. In fact, in winter when it's below -10C I almost never see the temp rise to the thermostat opening temp (85-90C).
    I wonder how many of you know that automotive temp gauges are designed to "lie". If the operator actually saw how much the temp varies and how quickly, they would (and have) panic! We don't have one, except for those of us with "Scangauge". I don't even know if we have a light. I'll have to check sometime. ;)
  19. Mendel Leisk
    38,213
    Yeah I'm starting to think I should pull those upper tubes out in summer.
  20. Rebound
    3,961
    2,609
    Portland, OR
    It's really the same thing. The coolant circulates to exchange the engine heat with the coolant, and the coolant in turn exchanges heat with the ambient air. So if the insulation increases air temps within the engine bay, it raises coolant temp and, in turn, engine temp. This would be particularly acute when the hot car is standing still, because there is no cooking airflow over the radiator.
    I say all this because monitoring coolant temp is at least as good as monitoring engine compartment temp. In fact, it's probably better because it more closely measures engine temperature, which is what matters most.
