Pinging with warm engine in hot weather
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TaiDinh, Jul 28, 2016.
  1. TaiDinh
    TaiDinh New Member
    Philadelphia
    Before posting, I have checked numerous of other threads for solutions and tried plenty of potential fixes, but the issue still occurs. My 2008 Prius with 80k pings during hard acceleration on a flat road, or moderate acceleration uphill. There's no CEL or hesitations from the vehicle. Cold/warm start-ups, cruise control, and idling is fine.
    I have tried the following:
    -Spark plug change
    -Various grades of gas from more than three locations.
    -Checked for overheating/coolant levels
    -Checked heat shields for rattling and any other loose nuts and bolts
    -Oil change.
    -Transmission fluid change.
    Wouldn't the knock sensor throw a code for me to see a Christmas tree on the dash? Faulty knock sensor?
    Ideas? What else am I missing?
    49,816
    would the egr, intake manifold, throttle body or maf affect it?
  3. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Anything in the VVT system? Just brainstorming, I don't know....
  4. CR94
    CR94 Senior Member
    2,642
    1,140
    Northwestern S.C.
    Why is your engine in water?
  5. Patrick Wong
    18,200
    6,479
    I think the OP meant to say "weather" in the title...
    I was wondering whether the OP still has pinging with 91 octane fuel.
    Okinawa likes this.
  6. TaiDinh
    TaiDinh New Member
    Philadelphia
    Title changed. :)
    If I am correct, 2nd gen doesn't have a EGR valve. I haven't gone as far as removing and inspecting the intake manifold, TB, and MAF for cleaning yet. Wouldn't hurt though, huh?
    Let me look into what a VVT system is and see if there's a solution for it. Thanks!
    I have tried two full tanks of 91 and 93 octanes. Same issues.
    Some suggested trying chemicals to remove carbon build up that may be creating hot spots. Input?
    Thanks, all!
  7. Patrick Wong
    18,200
    6,479
    Are you sure that the engine is pinging (vs. some other noise)?
    What did the old spark plugs look like?
    If your car has only 80K miles logged, I would not think there would be much carbon buildup.
  8. andrewclaus
    993
    324
    Golden, CO
    An engine problem should definitely throw a code, including the VVT (variable valve timing) system.
    I've heard a little about drive axles and wheel bearings pinging, but I can't imagine it would sound like an engine, or not give any other indications. But It might be worth pulling front wheels and making sure everything is tight.
  9. TaiDinh
    TaiDinh New Member
    Philadelphia
    Sorry, I should have been more descriptive from the beginning. The sound is closer to a metallic noise. Similar to pebbles being shook in a tin can from the engine compartment on the passenger side. I've check multiple times for loose nuts and bolts, but cannot find anything. Engine mounts are good. No front end accident on the car.
    All spark plugs just looks like worn plugs. 2nd owner. Plugs probably original before I changed it. Google image example attached.
    If you have any ideas what else to check, I will check. If it's not the engine related, it's still annoying.
    No harm to try that, will do.
  10. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    Doesn't look like those are platinum plugs...does it call for them?
    iPhone ?
  11. TaiDinh
    TaiDinh New Member
    Philadelphia
    I pulled the picture above from Google image. I have discarded my old plugs already. Picture from Google is just for reference of how similarly worn it looks. I installed four new NGK Iridium XL.
    trentofdestiny likes this.
  12. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I have that same noise in my 2015 prius v
  13. trentofdestiny
    1,104
    225
    Harrisburg, PA
    What's the spark plug change interval?
    iPhone ?
  14. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I think its another prius quirk. Meaning if it doesnt throw a code and someone doesnt know how to fix it exactly it could be anything. Causing the issue.
  15. Mendel Leisk
    38,985
    My guess, if changing plugs didn't help: carbon build-up in the top of the cylinder, which is doing a couple of things:
    1. Reducing air volume when the piston's at the top, effectively increasing compression ratio.
    2. Acting as little glow plugs, pre-igniting the mixture.
    Maybe just persevere with higher octane fuel, and try fuel treatment. Or something like SeaFoam?
  16. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    I actually tried all of those things. Also when I changed my spark plugs there was alot of carbon on the top of the piston. However the pinging noise only happens when the engine is cold. When its warm no noise.
  17. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    Also I ran 92 octane didnt change anything.
  18. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    Seafoam would help with the carbon buildup on top of cylinders. Maybe give that a try.
  19. bill02888
    bill02888 Junior Member
    Massachusetts, USA
    My 2005 (which I bought new in March of 2005) has been pinging for a few years. Currently at 193,000 miles. It seems to happen most when I'm going up a gentle incline. Can be a small road at 25 MPH or highway at 60 MPH. If I don't move the accelerator pedal it just keeps pinging. If I press down on accelerator pedal slightly the pinging gets a bit louder, sometimes starting to actually knock, at which point the Prius seems to notice it, and does something to make it stop immediately.
    I mentioned this problem during several visits to the dealer and they tried a few things but there is no change. They didn't see anything unusual. I've always used normal octane Top Tier gas which has the "recommended" amount of detergents. If I fill up with "special" (mid-octane) the problem goes away. I haven't noticed any correlation with temperature/weather/humidify.
    At one point I had them replace plugs. I asked them to look for carbon deposits while doing this. They replaced the plugs. I asked about carbon and got a vague response, as though maybe they hadn't bothered to check. It's always hard when you're talking with somebody who stands at the counter, not the person who actually did work on the car. Sigh.
    I have not yet tried SeaFoam. I have not checked/cleaned MAF or throttle plate.
    Help?
  20. Mendel Leisk
    38,985
    I'd suspect carbon build-up too. It creates little glow points and reduces air volume in cylinder head, raising compression ratio slightly. That using higher octane gas dispels the pinging is more evidence.
    Keep using mid-grade, for starters?
