HybridAssistant - Beta Testers Wanted!
Discussion in 'Prius OBDII Third-Party Apps' started by frenchie, Aug 27, 2016.
  1. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Hybrid owners using android and having an OBDLINK LX can test a new application.
    See all the details in above link
    It recognises automatically the car model and adapts itself.
    Until today, it was tested on P2, Gen3 (P3, P+, Auris, CT200h), YARIS, PRIUS C, RX400h, IS300h, RAV4h...
    No luck with P4...
    The application is free, no ads and available on playstore.
    Interfaces working well: OBDLINK LX, OBDLINK SX.
    not so well (not fast) : OBDLINK MX (wifi), Icarsoft BT620.
    badly (or not at all) the cheap chinese pseudo elm327.
    At this time, we are dealing with "normal" units (metric :cool: ).
    We are planning to adapt to Miles & °F within a short time.
    The application is stable enough but not completely finished (the sexy look will come later).
    There are 2 developpers Alessandro (who developped tools for analysing torquelogs)
    and myself (I am familiar to retrieving PIDs, I started with P3 followed by RX400h, IS300h and finally RAV4h).
    Enjoy
    SFO, bisco and Alessandro71 like this.
    49,797
    cool, all the best!(y)
  3. frenchie
    frenchie Member
    150
    48
    @bisco, In fact, I tested HA on Prius C (my daughter's car) in July, in Boston...
  4. bisco
    49,797
    i think i saw you!(y)
  5. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Thanks for doing this. I downloaded the App and it works fine with my OBDLink MX (bluetooth)
    I could not find the WiFi version as I realy wanted to test out my high speed OBD2 adapter which runs its internal UART bus at 2Mbaud..
    I use a high speed WiFi module from Espressif.
    Priidash likes to see a speed higher than 921600 to be able to execute the ATMA command on a CAN Bus running at 500K.
    SFO likes this.
  6. frenchie
    frenchie Member
    150
    48
    Bonjour ccdisce.
    Today, the application is not "finished", but you can use a wifi adapter:
    create in the application folder "_hybridassistant" a file named "connexionmode.txt".
    the content of this file should be the word WIFI
    config is the same as Torque: 192.168.0.10 , port 35000.
    If the content of this file is USB, HA will work perfectly with OBDLINK SX.
    With HA, we do not use passive frames. (Anyway there are not any more passive frames in actual models)
    Only requests, different depending on car model.
    By curiosity, you can activate obdlogging from Settings in ReportViewer and have a look to the logs (files starting with fx )
    SFO and alexgrigori like this.
  7. alexgrigori
    alexgrigori Active Member
    163
    108
    Technology
    frenchie, thanks for your assistance.
    Any luck with Prius gen 4?
    My intention is get access to the hybrid component info, like battery temperature, voltage, cooling fan speed, etc. Ideally, if possible, it would nice to map the status if individual cells in battery pack.
    #7 alexgrigori, Oct 12, 2016
  8. Maxroach
    Maxroach New Member
    London
    Looks good - downloading now! Will give feedback soon.
  9. SharkNX
    SharkNX Junior Member
    Bratislava, Slovakia
    Hey guys. Great job with that app.
    I've tested it with Samsung Galaxy S5 and S6 with Carista adapter and it works fine. All the app functionalities works.
    Is there any limitations to Android version? I would like to dedicate older Huawei tablet with Android 4.0.1 to run this app.
    Wysłane z iPhone za pomocą Tapatalk
  10. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
  11. frenchie
    frenchie Member
    150
    48
    the kiwi2 should work...
    the kiwi3 works very very slowly with HybridAssistant...
  12. alexgrigori
    163
    108
    Technology
    I've got the following iKKEGOL iCar 2 Mini OBD2 II Bluetooth Car Diagnostic Scanner:
    iCar 2 scantool is a high-quality automotive scanning tool, supports all OBD-II protocols :
    0.Automatic
    1.SAE J1850 PWM(41.6Kbaud)
    2.SAE J1850 VPW(10.4Kbaud)
    3.ISO9141-2(5 baud init,10.4Kbaud)
    4.ISO14230-4 KWP(5 baud init,10.4 Kbaud)
    5.ISO14230-4 KWP(fast init,10.4 Kbaud)
    6.ISO15765-4 CAN(11bit ID,500 Kbaud)
    7.ISO15765-4 CAN(29bit ID,500 Kbaud)
    8.ISO15765-4 CAN(11bit ID,250 Kbaud)
    9.ISO15765-4 CAN(29bit ID,250 Kbaud)
    A.SAE J1939 CAN(29bit ID,250*Kbaud)
    B.USER1 CAN(11*bit ID,125*Kbaud)
    C.USER2 CAN(11*bit ID,50*kbaud)
    Default settings(user adjustable)
    but HybridAssistant does not work with it for the reasons beyond my understanding.
    Am I doing something wrong?
    Please note that this adapter does work with Carista and Torque.
    #12 alexgrigori, Jan 20, 2017
