Spark Plugs & Ignition Coils
Discussion in 'Prius v Fuel Economy' started by Georgie-Hussel, Dec 27, 2023.
  1. Georgie-Hussel
    Georgie-Hussel New Member
    Richmond
    I recently bought a nice 2012 Prius V with 115,000 miles on it. No idea when new spark plugs & ignition coils last installed so decided to change them, my city gas mileage could be better, getting between 28 - 32 mpg city driving. I live in Virginia so currently temperatures are around 40 degrees.
    I noticed on Amazon prices for NGK spark plugs vary wildly, no idea if even half the ones are even legit and not knock-offs.
    I saw one set of Denso ones Cost $57.00
    No idea what brand of ignition coils to buy?
    I saw no NGK/Ignition coil sets together that I recall.
    Anyone have a link
  2. BiomedO1
    1,331
    729
    SacTown, Ca
    Ignition coils don't need replacement. I normally get more than 200K, before they start to fail.
    NGK, ND, even the Autolite iridium seem to last at least 100K miles. Drop the old plugs into the trunk in-case you get a failure.
    Brian1954 likes this.
  3. ChapmanF
    15,149
    Cheap plugs on Amazon are likely to be counterfeit, and sometimes the quality is such that an electrode or chunk of ceramic will fall into the cylinder and wreck your engine. Plugs from your dealer or a local brick-and-mortar job shop would be a better bet.
    If a coil ain't broke, replacing it with some inexpensive one may just mean putting something worse in your car than is there now.
    #3 ChapmanF, Dec 27, 2023
    douglasjre, Air_Boss and Brian1954 like this.
  4. Darth_Eric
    Darth_Eric New Member
    San antonio, texas
    When is a good time to replace coils? I haven’t had any problems with them I just hit 120K so I’m going to do the spark plugs. Just wondering how long the coils are supposed to last.
  5. ChapmanF
    15,149
    While anything can fail, and that can happen any time, I don't think they're really expected to, on any kind of schedule. They are solid-state electronics and copper wire wound around a core.
  6. BiomedO1
    1,331
    729
    SacTown, Ca
    My ignition coil issues usually presents itself as an intermittent miss that comes and goes. Most of the time it doesn't trip the CEL and it's usually gone when I try to find it. The one time it did trip the CEL, it was P0300 - pretty much useless; I knew I had a miss. 18 months later, it finally stopped firing, when the engine was hot. Let the engine cool down a bit and it was gone again. I swapped the 'bad coil' to another cylinder to verify which one was actually bad. A couple of weeks went by, it started missing again. I went straight for the suspected cylinder and that was it. Problem verified. The odometer is currently at 260K, on that truck - 5 old ignition coils and one new one. It would've been a lot easier, if it just out-right died on me - so I could find it.
    You can decide how often you want to change them, but beware - you may be installing counterfeit parts.
    Good Luck.......
    #6 BiomedO1, Apr 18, 2024
  7. douglasjre
    douglasjre Senior Member
    1,780
    618
    Orlando, FL
  8. Kenny94945
    Kenny94945 Active Member
    770
    394
    Sausalito
    2016 Prius v wagon
    FWIW...coils don't need to be changed for maintenance.
    Some co-members are saying a 200K life on a Prius, and I could agree.
    Some could say, they fail when they fail.
    Yet "no loss" except money, if you decide to change the coils.
    Sparkplugs... too many stories of counterfeit so buy with care.
    Either NGK or Denso should be fine; what does your owner manual suggest?
    But.... I would replace the spark plug wires instead of the coils as maintenance (11 years/ 115K mileage).
    Heat can "breakdown" the rubber and carbon of a spark plug wire.
    Enjoy your car :)
    douglasjre likes this.
  9. Mendel Leisk
    38,315
    I don’t think there are traditional spark plug wires?
  10. ChapmanF
    15,149
    Sure there are, just not in a Prius.
    douglasjre, Mendel Leisk and Air_Boss like this.
  11. Air_Boss
    Air_Boss Senior Member
    3,922
    1,071
    New Yawk
    Indeed. 10mm Magnecor leads from MSD electronic distributor to NGK BP6ES plugs on the sports car...
  12. douglasjre
    1,780
    618
    Orlando, FL
    Bpr6es plugs would foul even though they look normal. Bpr5es was the replacement that solved that problem. That was on Kawasaki and Nissan. Which engine and what application are you running 5es plugs?
  13. Air_Boss
    3,922
    1,071
    New Yawk
    NGK BP6ES in a U20 engine with B-cam, four throat Mikuni-Solex 44PHH-2 induction, crank-fired MSD electronic ignition.
    Tried Champion N7Y N8Y N9Y decades ago and never went back. Stopped throwing plugs at it.
