2009, Annoying High Pitched Whine when Playing Music via Bluetooth Adapter
Discussion in 'Gen 2 Prius Main Forum' started by dawsh2, Apr 24, 2024.
  1. dawsh2
    dawsh2 New Member
    Oregon
    Just bought an '09, and so far the only issues are oil burning (I'll be trying a piston soak this weekend and I just ordered a PCV valve replacement), and a high pitched whine when playing music over Bluetooth with one of those adapters that plugs into the cigarette lighter plug and broadcast an FM radio frequency. Any idea how to fix this? Also would love to hear any success stories w.r.t solving the oil burning. My '06 Corolla is at 215k miles and never burnt oil, the idea makes me a bit uncomfortable so I'm wanting to fix that ASAP.
    #1 dawsh2, Apr 24, 2024
  2. Tombukt2
    8,274
    1,434
    Yeah the '06 Corolla is a bit of a different animal a clean or burning engine and all this sort of thing but be that as it may. What is on the Prius right now? You may get it a little lower You may not get it to stop once it starts in the one NZ it's pretty much going to be a thing these engines are dirt cheap they can be rounded up everywhere and all parts of the world without issue if that becomes a thing I don't know I have an '09 that burns oil If I drive it my normal hundred miles a day or so once a week it'll be halfway down the stick with this car I generally let it get down almost to the bottom dot and then top it off to the upper dot never overfill I use cheap oil that doesn't really cost me anything so there's always that I have three other generation twos that don't burn oil at all the '09 is a work vehicle. The '09 also has 350,000 on it and it will probably never get its engine changed and I should be able to get it to 666k possibly beyond but it'll still be using oil like it is now or possibly more.
  3. Leadfoot J. McCoalroller
    6,873
    6,504
    Pennsylvania
    2018 Prius c
    If you can, try temporarily powering the adapter with a battery.
    If the noise goes away, then your problem is a ground loop. If it remains, you'll have to keep investigating.
