Prius 2010 issues. Display button do not work. Power windows do not work
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alexk345, Apr 26, 2024.
  1. alexk345
    alexk345 Junior Member
    40
    india
    hi
    Its to fix my car issues now. Its sitting there for 2 years but i drive the car weekly once.
    Initially battery down i normally does trickle charge and up.
    I think when i did oil change in canadian tire , they did some funky stuff. Display button stopped working after i came from oil change and battery went down. so i did boost that time but i think they did something and that is why battery drained.
    That time i was not interested in fixing because of covid i work from home
    But now i think i need to fix all car problems
    I bought new battery from canadian tire for 337cad
    1. Display and Trip (steering wheel) button do not work m, All other button work on steering wheel
    2. Power windows driver side work . Passenger and side power window stuck and dont go down. May be something jammed. I am gona clean the car in case something stuck
    Let me know how to bring power window back alive
    Thanks.
  2. Mendel Leisk
    38,345
    Geez you’re not kidding. When I tack on 12% tax (to $301 CDN price) I get $339.83 CDN, give or take a penny (roughly $255 USD).
    where was it sitting, outside? Maybe rodent damage: pull out glove box and check around the cabin air filter for starters.
    one thing puzzles me: your location is india??
    #2 Mendel Leisk, Apr 26, 2024
  3. alexk345
    40
    india
    Not really. It stopped working after i went to oil change in canadian tire. They screw it up. Do you know procefure to reset oil change indicator. When he finished oil change the warning was there and i went back told him to fix that. I think that time they screw it up.
    I am googling it for a while . i cant find a easy solution. I may have to take apart sterring wheel to see if those guys pulled out some pins.
  4. Mendel Leisk
    38,345
    Yeah could be.
