1. Offline
    Tom183 New Member
    Dec 29, 2009
    Message Count:
    652
    60
    Maine
    Your Vehicle Year:
    #1 recommendation for highway driving in cold weather: pump up your tires
    750 miles in 35F @70mph = 43.3mpg (actual) (45.6mpg displayed)
    Just did a round-trip of 750 miles, 95% of which was highway at 70mph (the other 5% was short trips around 40-60mph, so they actually hurt the overall mileage). Temps ranged from 30-40F, altitude went from sea level to almost 2000ft and back again (with a 2nd climb of 1000ft in the middle).
    I recently changed my tire pressure to 42/40psi front/back - similar runs (in slightly colder temps) were as low as 39mpg actual with the tires at 37/35 and almost the same grill blocking.
    After factoring out the temperature difference, I think the additional 5psi gave back about 2.5-3mpg highway.
    So, the #1 recommendation I have for cold temps: pump up your tires. You will feel the bumps more, but on reasonably good pavement you won't notice (in fact, I think firmer tires may be a bit quieter). Just remember to let some air out when temps warm up again.
    1 people like this.
  2. Offline
    adamace1 New Member
    Jun 22, 2009
    Message Count:
    1,100
    108
    Charlotte, NC
    Your Vehicle Year:
    I didn't notice much if any of a difference from psi of 40, so i just run mine around 34 i'm not saying others wont, but the extra wear on the suspension parts/tires and me doesn't seem worth the little if any mpg effect. I'm not trying to say it didn't help you. But i'm wondering if alot of the people complaining about rattles, and how their car rides has something to do with overinflated tires?
  3. Offline
    mmichaell New Member
    Dec 16, 2009
    Message Count:
    241
    16
    chicago
    Your Vehicle Year:
    You know, I didn't notice any rattling when driving home from the dealer 2 months ago. The dealer inflated the tires to about 32/32 so they were extra cushy/comfortable. Now at 38/35 the comfort is just okay. I'm mainly worried about suspension as you are.
  4. Offline
    smartalec89 The Official Alaskan
    Nov 16, 2008
    Message Count:
    133
    anchorage, alaska
    Your Vehicle Year:
    I wouldn't worry about the suspension if you are just driving on pavement. If you rally it on dirt roads, like I've done with my genII, then worry. Otherwise its a Toyota and they are built to last so inflate away my friends. :D
  5. Offline
    Tom183 New Member
    Dec 29, 2009
    Message Count:
    652
    60
    Maine
    Your Vehicle Year:
    I think rattles can be an issue even with the stock PSI, but softer tires do soak up bumps more. I'm not worried about the suspension, shouldn't be an issue unless your roads really suck.
    I should have titled the thread "#1 recommendation for highway driving in cold temps" - I don't think the difference is quite as noticable at lower speeds, although it is still there to some extent.
  6. Offline
    pakitt New Member
    Aug 10, 2009
    Message Count:
    1,081
    220
    Munich, Germany
    Your Vehicle Year:
    The thing that really changed my MPG is setting ECO mode and the heater to 16C/61F (the minimum before the "LO" setting) since I keep the coat on (overall commute trip 25mins). It looks like cold, but it is bearable and you see a true benefit in fuel consumption. Otherwise I would keep it at 22C/72F.
    The engine does not turn on so often during stops at traffic lights and overall fuel consumption has improved considerably (0,5L/100km-5mpg less on average). Also warm-up is shorter.
    On longer trip outside of town, this likely does not help - I agree.
    Wheels are pumped nominally and I get regularly about 4,3L/100km-55mpg on the evening trip (less traffic) and 5,3L/100km-44mpg on the morning one (more traffic). This with temperatures around 0C/32F.
  7. Offline
    LulzChicken New Member
    Jul 19, 2009
    Message Count:
    662
    78
    Florence, AL
    Your Vehicle Year:
    I can also agree. I've tried various techniques to obtain better mileage during the winter. Pumped up my tires to 41 front and 40 back. I'm mainly driving short trips <10 mil. which also hurts my mileage. However, as I do go on longer trips my mileage for that tank creeps up. So, I do know I CAN get the better mileage, it's just that the short trips and long warm-up times hurts the MPG's.
  8. Offline
    alokeprasad New Member
    Dec 6, 2009
    Message Count:
    132
    Ohio
    Your Vehicle Year:
    Over-inflating tires will reduce traction. May be an issue with some in the snowy/slushy states ...
    1 people like this.
  9. Offline
    john1701a New Member
    Jan 6, 2004
    Message Count:
    5,511
    968
    Your Vehicle Year:
    Over-inflating means to EXCEED the maximum pressure listed on the wall of the tire. Modern tires will retain their shape surprisingly well up to that point.
    42/40 is under the maximum of 44.
  10. Offline
    • Moderator
    May 11, 2004
    Message Count:
    13,921
    1,217
    Far-North Chicagoland
    Your Vehicle Year:
    This point has come up so many times in the last half-decade that very determined testing has been done. You can find the results showing improved handling, reduced stopping distances, extended tire life and even tire wear and improved mileage throughout PriusChat, CleanMPG, GreenHybrid and I'm sure many other locations.
  11. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    Message Count:
    321
    117
    Princeton, WV
    Your Vehicle Year:
    Im running 50 PSI right now, and there's been snow on the ground since December 18th.
  12. Offline
    Tom183 New Member
    Dec 29, 2009
    Message Count:
    652
    60
    Maine
    Your Vehicle Year:
    I'm using snow tires, so even if there were a marginal change to the tire qualities due to the added (not "over") pressure, the snow tires still make a huge gigantic enormous difference over the OEM's in crud.
    The snow tires also cost me about 2mpg vs the stock tires (on clear roads), so if I used the OEM's with the higher pressures I would expect to get 45.5mpg or possibly 46mpg in the same temps at the same speeds - that gets a lot closer to the 48mpg EPA highway, which should be easy to beat on a regular basis as soon as temps get over 40F or so. (they were the past day or so, and my displayed mpg is at 51.4 after more than 100 miles of "around town" driving)
  13. Offline
    Tom183 New Member
    Dec 29, 2009
    Message Count:
    652
    60
    Maine
    Your Vehicle Year:
    This would carry more weight if you could link to a few of the key threads - but I'm not surprised at what you're saying, manufacturers almost always use less-than-optimum tire pressures in order to increase ride comfort.
  14. Offline
    Tom183 New Member
    Dec 29, 2009
    Message Count:
    652
    60
    Maine
    Your Vehicle Year:
    For non-highway, this plus some grill blocking is likely the best formula.
  15. Offline
    barnabas New Member
    Nov 24, 2009
    Message Count:
    34
    new hampshire
    Your Vehicle Year:
    I have been to two different dealers for service. Both dealers have increased the tire pressure to the max shown on the tire side walls 44 PSI. Yet the door plate shows 36 front and 33 back for recommended inflation. I see about 3 or 4 MPG better with the higher tire pressures. I keep bringing the tire press back to half way between the dealer pressures and the door label pressures. I am concerned about the wheels with the higher tire pressures. Some manufacturers have had problems with wheel fractures from over inflation.
    Do the dealers have some sort of tech notes or instruction to increase the tire pressure beyond the door labels?
    Barn
Share This Page
