1. Offline
    Seamus Murray New Member
    Start a Conversation
    May 25, 2007
    I have a 2007 fully loaded generation 2 Prius. From time to time over the past four years I have had occasion to see it in the car and listen to the radio for approximately 20 or 30 min. Up to the end of last year this has not been a problem. Unfortunately three or four times this year listening to the radio for approximately 20 min has caused the 12 old battery to fully discharge. Leaving it impossible to start the car. Then having to get jumper cables to start my prius. Has anybody experienced this? It seems ridiculous that the battery should fully discharge after this short period of listening to the radio. In standard cars you can listen to the radio for at least 3 to 4 hours easily. Why should the 12 old battery in the Prius be any different to the battery that is in standard cars? I look forward to receiving any help or suggestions any of you may have. I am located in Dublin Ireland, not that that should make any difference as all Toyota prius's come from the same source. Regards Séamus Murray
  2. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,347
    670
    Wilmington, NC
    Your Vehicle Year:
    First, the Prius 12V battery is smaller than a standard vehicle because the battery does not have to start the ICE. The ICE is turned over by MG1 (electric motor-generator) and the HV battery. So, the Prius battery is more susceptible to discharge than a typical car battery.
    Second, the normal life expectancy of a battery is 4 to 5 years. Since yours is a 2007, and it has been fully discharged multiple times, I would highly recommend replacing the battery.
    Third, if you want to listen to the radio for any length of time, keep the car in Ready mode. This way the HV battery is providing the 12V for the radio and to keep the 12V battery charged. When the HV battery SOC gets low the ICE will start and keep the HV battery recharged.
  3. Offline
    stevemcelroy Active Member
    Jan 25, 2009
    740
    127
    Wallingford, PA
    Your Vehicle Year:
    You will have the same sort of issue with any car and an old and failing battery.
  4. Offline
    Apr 14, 2009
    5,934
    1,663
    Greenwood MS USA
    Your Vehicle Year:
  5. Offline
    Mar 8, 2008
    10,573
    2,454
    Your Vehicle Year:
    1. Replace the 12V battery now. It is obvious the existing battery is near-dead.
    2. When the 12V battery has discharged, do you charge it at least overnight? If not, the battery never has an opportunity to recover and is highly susceptible to further discharging as plate sulfation occurs and the battery capacity diminishes.
    3. If the 12V battery is fully-charged then you should be able to listen to your radio while in ACC-ON mode (where no instrument panel warning lights appear) without difficulty for several hours.
    4. If your habit is to leave the car in IG-ON mode (where most warning lights are on) then a very high current drain exists and the 12V battery will quickly discharge.
  6. Offline
    Apr 14, 2009
    5,934
    1,663
    Greenwood MS USA
    Your Vehicle Year:
    Assuming the OP has the stock radio, not modified the Sound System.
  7. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,415
    Santa Fe, NM
    Your Vehicle Year:
    You are in Ireland? Can you get an Optima YTS 2.7J? It is a drop-in replacement deep cycle battery -- absolutely perfect for what you want to do. Only problem is that it is not available in the US, but it is in the UK! So your location does make a difference.
    After running down the OEM 12V once or twice, it will never be the same.
  8. Offline
    May 25, 2007
    Mr Collins, many thanks for your extremely detailed and informative reply, I am extremely grateful. I will book occur in to have the 12 V battery replaced by my Toyota main dealer. Regards, Séamus Murray
    1 people like this.
  9. Offline
    May 25, 2007
    Standard radio fitted by Toyota, many thanks for your reply.
  10. Offline
    May 25, 2007
    Again many thanks for your reply Patrick. With the information received in all the replies in the future when listening to the radio I will leave it in ready mode. Your help is very much appreciated.
  11. Offline
    cjcj1949 New Member
    Oct 11, 2011
    uk
    Your Vehicle Year:
    I'm an engineer and I don't think users should have to put up with the 12V battery failing. It will fail eventually but it is easy for a car like a Prius to monitor the state of the 12V battery. It should also be checked in services and a sensible specification should exist for replacement. If Toyota think we need a 30AH battery then we need at least a 15AH battery to keep running. My car was sold to me with a 5AH battery that went flat went I used a compressor to pump up the tyres. The real problem is that 12V batteries need to be tested on a Prius. They need to do so little that they will be in a very bad state when the non technical driver can't turn on the computer.
    I think they should be using the same care to look after the 12V battery as they do with the HV. A Prius 12V Battery does not need to be charged at 20Amps and neither does it need to be kept at 14V. This will just overcharge it. The float volts for a 12V battery is not 14V but more like 13.3 to 13.7.
  12. Offline
    David Beale Senior Member
    Jul 24, 2006
    3,795
    460
    Edmonton Alberta
    Your Vehicle Year:
    Well, I'm not sure what facts you are talking about, but the following apply to the Prius 12V battery system:
    The stock battery is a 38 A-Hr unit.
    The "float voltage" is 13.8V when the Prius is in "ready". If it were lower the battery would never reach a reasonable state of charge unless driven for many hours at a time. If it were higher the battery life would be even shorter than it currently is.
    If -your- battery had a lower capacity it has been damaged by over-discharging it and not fully charging it back up.
    Like -any- lead acid battery, if discharged too much the battery will sulfate and its' life will be shortened.
    The -real- solution for the Prius 12V battery would be to replace the lead-acid battery with a NiMH unit. Except it would be very expensive (and of course would require redesign of the charging system).
  13. Offline
    cjcj1949 New Member
    Oct 11, 2011
    uk
    Your Vehicle Year:
    Lead acid batteries do not sulphate/ sulfate as soon as they are discharged. Sulphation takes time. If you recharge a completely flat battery within a few hours at a current of less than C10 it will recover happily. Sometimes the volys from a lead acid battery will increase as it is discharged as old chemicals are dissolved away. Sulphated batteries can also be charged with various methods that often work.
    A solution for the Prius that would enable the 12V batteries to last a lot longer would be to limit the charge to 4 amps at 14V with a short boost to 15V. Followed by maintenance at the correct float voltage. An indication could also be supplied to the user of the current battery state of charge, and capacity and also its internal resistance. Not difficult. For the non technical a replacement time estimate could be given.
    If you do flatten a 12v battery, do not fast charge it in the vehicle. Disconnect and charge it with a safe battery charger. It is not needed to supply high currents, and there is no reason for it to be deeply discharged. The car could even switch the load off before the battery gets so low that the computer cannot be booted. The high load will soon die anyway, why not switch it off before it discharges the battery below the computer boot on level.
    There is still much energy available below 9V and that could be used with a cheap convertor to start up the computer or at least energise the HV relays to allow the 12V battery to be charged from the HV via the DC to DC convertor.
  14. Offline
    sidecar Member
    Dec 29, 2010
    247
    17
    Australia
    Your Vehicle Year:
    this may well become the 'rough guide' for battery testing, no instrument required
  15. Offline
    driveranndrews New Member
    Jun 16, 2012
    Bristol U.K.
    Your Vehicle Year:
    Just a thought, but surely the MFD would consume a lot of power from the 12v battery as it's an old cathode ray
    design. Another reason to have the system switched to ready mode when listening to the radio.
  16. Offline
    Britprius Senior Member
    Jun 14, 2010
    2,584
    591
    Herefordshire England
    Your Vehicle Year:
    Seamus the Optima battery is very good but in Europe is very expensive, UK price is £184. There are many other good batteries on the market here that are less than 1/3 of the price with longer guarantees and of higher capacity. Look at Varta and Bosch and Lucas they do 4 and 5 year guaranty batteries at around £40/60.
    The Toyota battery is £90 with 1 year guaranty I believe the Optima has a 3 year.
    John.
  17. Offline
    Jun 14, 2010
    2,584
    591
    Your Vehicle Year:
    The MFD is not a cathode ray tube it's an LCD.
    Andyprius # 1 likes this.
  18. Offline
    Jun 14, 2010
    2,584
    591
    Your Vehicle Year:
    I already run a system for 12v battery recovery in case the interior light is left on etc. I use a small switch mode power supply from an old laptop computer fed via a DP switch from the HV battery. This feeds an LM317T connect as a current regulator set for 3amps and on to the 12v battery.
Share This Page
