12 v Power outlet not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Airbalancer, Oct 30, 2011.
  1. Airbalancer
    Airbalancer
    Expand Collapse
    Active Member
    891
    71
    Cobourg, On, Canada
    the outlet in the dash is not working but the one in the arm rest is
    where is the fuse panel for the inside connection?
  2. johalareewi
    johalareewi
    Expand Collapse
    Member
    393
    uk
    From memory, it is the fuse box under the hood (back right hand side) rather than the one under the panel in the passenger footwell. The owners manual will tell you and which fuse you need to check. There is a fuse removal tool in the main fuse box (engine bay) and a few spare fuses.
  3. Airbalancer
    Airbalancer
    Expand Collapse
    Active Member
    891
    71
    Cobourg, On, Canada
    saw the one under the hood, but in the manual it shows one that is inside
    that is the way I read it anyway
  4. RRxing
    RRxing
    Expand Collapse
    #burlivesmatters
    1,374
    559
    Long Island, NY
    The layout for both the engine compartment and passenger compartment fuse boxes is in the manual.
  5. Airbalancer
    Airbalancer
    Expand Collapse
    Active Member
    891
    71
    Cobourg, On, Canada
    but where do I find the passenger fuse box:confused:
  6. jdcollins5
    jdcollins5
    Expand Collapse
    Senior Member
    4,903
    1,063
    Wilmington, NC
    The passenger fuse box cover is right next to the engine hood release lever.
  7. Gary Otto
    Gary Otto
    Expand Collapse
    Member
    123
    Silver Springs, FL
    The fuses for both outlets are located in the fusebox under the drivers dash. They are both 15A fuses. PWR OUTLET is #3, CIG is #1.
  8. Airbalancer
    Airbalancer
    Expand Collapse
    Active Member
    891
    71
    Cobourg, On, Canada
    thanks, but who can see anything down there :eek:
  9. Airbalancer
    Airbalancer
    Expand Collapse
    Active Member
    891
    71
    Cobourg, On, Canada
    Thanks all, new fuse all is better
    But they do need a new location for this fuse box
  10. ejprez
    ejprez
    Expand Collapse
    New Member
    Erie
    Both of mine in my 2005 do not work, I replaced both 15a fuses and still no power in either. What else should I look at, can I just replace the outlets if they are fried, looks like they just disconnect and pop out.
  11. qbee42
    qbee42
    Expand Collapse
    My other car is a boat
    18,040
    2,983
    Northern Michigan
    Are you sure you replaced the proper fuses with good replacements? It's hard to fry a power outlet when it is properly fused.
    Tom
