12 volt batteries problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KailuaPrius, Sep 13, 2010.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You should have many batteries that will do the job. I have used a small Honda battery ( 55AH ) wet cell, a 7 AH sealed Gel. Also just rejuvinated my 12V by adding a bit of H2O ( 1/2 oz ) plus giving it a three day trickle charge. The SOC seems equivalent to a new battery. ONE thing, you will probably have to file down the positive post to accomodate the Japanese pos cable. So far I have found no hardware to make this job easier. Good Luck. :cheer2:
  2. jstack
    jstack New Member
    211
    38
    Chandler Arizona
    I
    Be sure it's really a bad 12 volt battery, mine was going crazy , systems shut down like AC, brakes etc,
    It turned out to be a bad 12 volt water pump that pulled the 12 volt low. They say it's normal for the system to shut down all 12 volt items.
    The display screen kept saying , abnormal brake and other worthless info.
    I out a new battery in myslf, then found it was the pump after 2 dealer visits.
    DO IT YOURSELF, they don't have a clue.
  3. andyprius
    2,212
    188
    Interesting info, jstack.:D
  4. JesterScott
    JesterScott New Member
    Shreveport, La
    ok I'm still new to the prius world. How do I know if my battery is going bad?
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
