127SNI135 PAC SNI-1/3.5 Noise Filter solves AUX input issues
Discussion in 'Gen 2 Prius Audio and Electronics' started by navguy12, Feb 3, 2012.
  1. navguy12
    navguy12 Member
    193
    30
    Batawa Ontario
    Aux input electronic noise problem solved!!!!!!
    My thanks to the other folks in this forum that pointed the way to solving the (OEM stereo) aux input noise issues with this unit ($CDN 36.93 delivered):
    http://www.crutchfield.ca/ShoppingCart.asp
    USA link here ($US 17.99 delivered):
    PAC SNI-1/3.5 Noise Filter Helps eliminate ground loop noise from your portable music player! (3.5mm plugs) at Crutchfield.com
    To order the Toyota Canada parts for the Toyota fix to this issue ([FONT=&quot]T-SB-0067-08 Rev 1 dated 21 May 2008[/FONT]) would have cost me $CDN 195.00 plus HST.
    Cheers
    Mike
  2. cnschult
    cnschult Active Member
    772
    85
    Michigan
    Both my 04 and 05 prius have cassette decks so I used to always get hissing noises out of them with a cassette adapter, especially classical and opera music played loudly, but then I found a white Phillips cassette adapter ($9 or $10 at sears) and the hissing is gone, so I'm just gonna throw that out for the owners of older Prius that don't want to spend the time and/or money on an aux input or ipod dock.
  3. rosco64209
    rosco64209 Junior Member
    FL
    Just bought a new tablet and when i had it charging (in car) and 3.5mm plugged in it will hiss really bad (when not charging, it wont hiss with 3.5 plugged in. When i have my cell charging and 3.5mm plugged in, it won't hiss. I'll have to try this out... thanks for the info!
