12v battery replacement cost
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rickster, Jul 6, 2011.
  1. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Ok, just checking. :)
  2. redrockprius
    redrockprius redrockprius
    167
    30
    Murray, UT
    I had the dealer replace my 12-volt battery yesterday for $197 for the battery and one-half hour labor ($47.50) for a total of $244.50 plus tax.
  3. gocruik
    gocruik New Member
    Had the 12 volt replaced by AAA Battery Replacement (Bay area, Northern Calif) service in my drive for $125. No charge for labor. Three year guarantee.
    I was impressed.
  4. Patrick Wong
    18,198
    6,464
    How about posting photos of the new battery? I'd like to see what was installed.
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i moded a civic battery... it seems much more reliable in cases where a light gets left on.... i think the whole setup cost me less too. i'll re check price. the only thing is, you lose that vent (hope it never blows)... and you need to modify the hatch floor/battery cover and connectors to work (add in connectors)... i totally rigged mine...
    maybe i'll take a pic later...
  6. dmiller80202
    dmiller80202 Junior Member
    Colorado
    In Denver on 5/12/12 Mtn States Toyota is running a special to replace 12v battery on Prius (mine's an '05) for $99.95. Comes with 84 mo warranty and 2 yr free replacement.
    Seems like a deal to me.
  7. MashinA
    MashinA Junior Member
    32
    my dealer wants to charge me $399 installed....how are you guys getting it for $200 :/
  8. SteveLee
    SteveLee Active Member
    645
    179
    North Carolina
    I
    Well, that is worse highway robbery than usual. The OEM battery is less than $200 and it takes 30 minutes at most to install. $300 out the door is the norm for the Prius battery replacement at Toyota dealers. But it doesn't take a certified Toyota technician to replace the 12V battery. And there are other options to the overpriced OEM battery and even some of the more recommended alternatives.
  9. JPP
    JPP Junior Member
    26
    I just replaced it on my 2008. It was like $197 for the battery and they wanted about $50 for installation. I did it myself. I am not the greatest mechanic so it took me a little over an hour to do, but I did it. Just watched a couple you tube videos on how to do it.
  10. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    When I did ours, I bought the battery from the dealer and installed it myself. I wrote up a post on the installation. You can find the link in my signature below. It doesn't take a lot of tools and can be done by anyone who has mechanical ability and uses common sense. The dealers want TOO much money for the installation.
  11. bobeast
    bobeast Junior Member
    39
    23
    There is no voodoo here. It's just a battery. IMO the Optima is overkill, but if thats the way you want to go, you can pick one up on amazon for about 170. If you want to get more creative you can switch over to standard terminals like these and grab an $80 special from pep boys. Move along. nothing to see here.
  12. dorunron
    3,318
    1,103
    Houston, TX
    Can you post pictures of your "creativity" that you have done on your Prius?
  13. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I obtained a 12v replacement battery (yellow top) for a great price from Amazon.com.
  14. bobeast
    39
    23
    Any more "questions"?
  15. dorunron
    3,318
    1,103
    Houston, TX
    LOL I asked you to post a picture of your "creativity". I was implying the use of the emergency terminals that you linked to in your post in an actual 12 volt battery installation on "your" Prius as well as a standard type battery which you had suggested. I did not ask for a youtube video on how to change the battery. I am very familiar with how to change the 12 volt battery in the Prius.
    For the record, I would never recommend to anyone to use "emergency type" terminals such as these. Universal Top Post Battery Cable Terminal Red / Black : Amazon.com : Automotive
    You would have to either fabricate some sort of adapter to fit the small clamps on the cables from the Prius and then connect that adapter to the terminals, or cut away the original small clamps which would cause more damage than good. But, if you want to mod your Prius that way, be my guest.
    But thanks for the reply anyway. It definitely made me smile and laugh.
  16. mbooth62
    mbooth62 Junior Member
    28
    San Jose. CA
    Go to another dealer .. Mine was around $200 inc labor at piercy Toyota in sf Bay Area ...
  17. kenoarto
    kenoarto Senior Member
    395
    Chicago, IL
    looking for a link to an $80 Prius battery...
  18. SteveLee
    645
    179
    North Carolina
    I
    I think within this link there is discussion about using mobility batteries that are more than adequate for Prius use and are deep cycle that are below $100 and I think around $80, though it takes a little modification.
    Fitting mobility 12volt AGM battery. | PriusChat
    kenoarto likes this.
  19. sportcoupe
    sportcoupe Junior Member
    44
    I got the optima for $144 shipped from ebay using a 10% discount code. Best deal on a direct fit no fuss 12v battery replacement. Took 20 mins to install with basic tools.
  20. kenoarto
    395
    Chicago, IL
    10% discount code?
