12V battery substitute: $99 LiFePo4?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jerrydelrey, Jun 17, 2013.
  1. jerrydelrey
    jerrydelrey Member
    111
    22
    Honolulu Hawaii
    Can I use this $99 LiFePo4 battery to replace the 12V battery? If not, any suggestions?
    Amazon.com: 12V 9Ah, StarkPower, Lithium Phosphate Battery (LiFePO): Electronics
    "Product Description
    StarkPower's "UltraEnergy" Lithium Iron Phosphate (LiFePO4) battery is the ultimate in weight versus power technology. This is a drop in replacement for your Lead-acid battery, and will require no change to your existing system. It can be placed in scooters, wheelchairs, UPS Backups, photography or anything that uses a sealed lead acid battery.
    LifePO4 contains no poisonous lead, no acid, and does not create gasses during charge, as traditional Lead-Acid batteries do. Compared to lead-acid, Lithium Iron Phosphate batteries are also extremely light, have much lower self-discharge, do not sulfate, and are environmentally friendly.
    StarkPower "UltraEnergy" Models have a Battery Management System (BMS). BMS monitors the key operational parameters during charging and discharging such as voltages, currents and internal temperatures.
    PRODUCT SPECIFICATIONS:
    Model No. SP-12V9-EP
    Voltage: 12V
    Capacity: 9Ah, 90Wh
    Chemistry: LiFePO
    Weight: 2.8lbs (1.3kg)
    Dimensions: 5.9"(L) x 2.6"(W) x 3.7"(H), [150mm(L) x 65mm(W) x95mm(H)]
    Life Cycles: 2,000 @ 80% DOD
    BMS YES (Internal)
    Max Charge Voltage: 14.6V
    Discharge Cut-off Voltage: 8.2V
    Max Charge Current: 9A
    Max Discharge Current: 15A
    Operating Temperature: -22°F to +140°F, (-30°C to +60°C)
    Connectors - T2 (F2, 0.25 inch, 6.4mm) Spade Terminals
    FEATURES: Ultra light. One fifth the weight of lead-acid batteries on average Twice to four times the service life of lead-acid batteries Drop-in replacement for your OEM battery Fast recharge rate No explosive gasses during charge, no lead, no acid Environmentally friendly
    SAFETY: Internal over charge protection. Internal low voltage protection. Internal short circuit protection. Internal cell balancing. Auto Restart function. No presence of toxic substances. "
  2. CygnusX-1
    CygnusX-1 Junior Member
    I'd be concerned with these two specifications for using it as a replacement to the 12V battery.
    48,987
    optima or toyota oem.
  4. El Dobro
    El Dobro A Member
    6,972
    3,209
    Looks like the battery I use for back-up on my house's alarm system. With those terminals, it's not for a car.
  5. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    This is a 9 a-h battery...about 25% the size of the OEM 12v battery. It is not going to work unless you use four of them. Additionally, LiPo batteries use a different charging scheme than lead-acid and may not be compatible with the existing system.
  6. JANSone
    JANSone JANS one
    87
    OC, CA
    If u need a battery let me know. I work for a company that provides backup power for datacenters so we buy dozens if not hundreds of batteries every month from various vendors, so our cost should be better than anything out there. I bought an Optima for my GenII six months ago and it was like $175 (no tax cause of our resellers license) and it was at will call at the closest distribution center the next morning. Anyways, if u are interested, let me know and I can ask my vendors, and give me a heads up on what it is u need...
  7. jerrydelrey
    jerrydelrey Member
    111
    22
    Honolulu Hawaii
    The Prius starts off using the Traction Battery. So I didn't think that the Prius actually needed alot of Current. Just enough to power the computers.
    Does the accessories run off a DC-DC converter? Or off the 12V battery?
    JANSone, Thanks for the offer.
  8. drysider
    823
    332
    Liberty Lake WA
    Most of the accessories use 12v. They run off of the battery, which is then recharged thru a dc-dc converter from the HV side. A 9 a-h battery doesn't have enough capacity to run very much if the engine is off, and you will need an external jump to start the car if it runs down.
    jerrydelrey likes this.
  9. MattNiem
    MattNiem Junior Member
    52
    Finland
    Hello everybody! Would a LiFeYPo4 battery work as a substitute? Dimensions and charging behaviour are similar for Winston 40 Ah 12V, but it weighs less and has more capacity.
  10. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    As a 12v battery in the Prius plays a bigger role than most "normal" cars, I wouldn't try to skimp or save on it too much. I went with an Exide which has the same specs as the Toyota Yuasa unit. The people in the US seem to replace with the Optima, but there have been the odd issue with them recently as I've read here. If the OE unit lasts for 5+ years, that's not a ba one to go for again. I saved money by fitting it myself rather than pay and hour or two labour in the garage
    #10 Tony D, Sep 23, 2014
  11. MattNiem
    52
    Finland
    Bigger role? My impression was that it's almost like a bios battery in a laptop :) No need give massive currents to start the ICE, and charging with DC-DC converter is also much more civilized compared to alternator of a normal car. Lithium alternatives aren't cheaper actually, but they have other benefits.
  12. Mendel Leisk
    38,247
    This kinda reminds me of the transaxle fluid. Owners Manual says use fluid A. No ifs, ands or buts. Just use that, nothing else. We're warning you... Owner's response:
    How about this other stuff?
  13. Tony D
    468
    132
    Dublin, Ireland
    It's up to you at the end of the day. I went with an Exide as they're recognised as a good brand here in Ireland and also in UK. I can get considerable discount on the Exide (cost less than €70), so went with it as it's specs were better/same than the OE one, only alot cheaper for me.
    I just gave my opinion, I don't know what the GWL batteries are like as I don't think that they're sold here in Ireland, maybe they're a known brand in Finland
    73
  14. MattNiem
    52
    Finland
    Well 70 € or below is such a low price that it's easy to understand your position. Battery technology marches on though, and maybe in a few years we could see even some known brand to advertise lithium-based start batteries as a premium alternative. Time will tell. Thank you for input!
  15. ChangeMachine
    ChangeMachine New Member
    Portland, OR
    Any thoughts on the EarthX ETX680C or other such batteries? And by thoughts, I mean data. "Stick to the recommended" is covered. We get it, but new tech is available that wasn't available when my manual was printed. What specs are we looking for? I see people ruling out the specs posted by the OP but not saying what the specs SHOULD be. Can anyone be more specific? I've read that the original (Yuasa?) was around 38AH or so, but I've had no luck determining what the charge current applied to the 12v from the DC converter is. Something less than 100A is all I can dig up.
  16. Mendel Leisk
    38,247
    It's "posts" are completely imcompatible with the stock cable clamps. Being described as a "motorcycle battery" I'd guess it doesn't have the proper vent port?
  17. Jarkko
    Jarkko Junior Member
    36
    Finland
    2012 Prius+ MPV
    Charge and discharge currents are a question mark. Toyota does not specify maximum currents, so we must quess. There is a 200 A fuse for the battery, so that's an absolute upper limit discharge current. In practice you do not have to reach 200A discharge current as LiFePo4 would not fail with overcurrent. Also maximum discharge would happen when the car is not in fully-on-state and you have all accessories running. I find it hard to belive that the power consumption would be over 2kW (maybe with DC-AC converter).
    Charge current estimate depends more on battery chemistry. Toyota does constant voltage charging around 14.7 V (sometimes the charge voltage drops, but it is still constant voltage). There is also a current limit at some level (I do not know exactly), but it is likely shared with other 12V sinks. If your LiFePo4 battery is near full, there is no problem with charging current. But if it is near empty, there could be issues :)
    I have now driven a little bit over one month with Winston 40Ah battery - all fine for now..
  18. ChangeMachine
    Portland, OR
    Thanks Mendel. John Frum cargo cult? Fascinating. I'm focusing now on the EarthX etx680c battery, which has automotive applications. Being Lithium, it doesn't vent anything. Unless it blows up. :) The terminals are different. Not a real barrier.
    Thanks, Jarkko. ChapmanF referred me to this post which seems to reliably peg the charge current at 60A. Maybe 70? 60A and 15V are the upper limits for the EarthX battery. Its rated at 36AH "Pb equivalent" (12.4AH actual). That, too, seems within spec, and since it's 1/2 the size of the spec battery, it looks to me like a legit drop-in (with terminal mods) replacement. Am I wrong?
    You make a good point about HOW a Prius USES the 12v, Jarkko. You obviously know a lot more about electric sorcery than I do, but I was mulling similar thoughts over and sent an email to EarthX asking for advice.
  19. ChangeMachine
    Portland, OR
    Thanks, Jarkko. ChapmanF referred me to this post which seems to reliably peg the charge current at 60A. Maybe 70? 60A and 15V are the upper limits for the EarthX battery. Its rated at 36AH "Pb equivalent" (12.4AH actual). That, too, seems within spec. Since it's 1/2 the size of the spec battery, it looks to me like a legit drop-in (with terminal mods) replacement. Am I wrong?
    You make a good point about HOW a Prius uses the 12v, Jarkko. You obviously know a lot more about electric sorcery than I do, but I was mulling similar thoughts over and sent an email to EarthX asking for advice. Stay tuned.
  20. ChangeMachine
    Portland, OR
    A thought on the Lead-Acid (LA) equivalent concept, and how it applies to Prii: For those wondering, LA equivalent refers to the fact that regular ICE cars depend on high-draw starters. At ~ 70% charge a LA battery doesn't have the voltage to power a starter. Lithium functions down to about 5% charge, and is thus equivalent to a bigger LA battery for high draw use.
    Since a Prius 12v battery only sees light loads (computer, stereo, etc) which I'd GUESS stays below 5 or 10A, the equivalency factor might be less important in relation to the real AH rating. Disclaimer: I'm not an expert, I'm just piecing this info together. If my logic is logical, something like the ETX900 (16AH) or ETX1200 (24AH) should be a better fit. $725 for the latter, FWIW.
