Stump the Chump, Gen 3 edition
Discussion in 'Gen 3 Prius Technical Discussion' started by ChapmanF, May 31, 2016.
  1. ChapmanF
    17,517
    I haven't seen a StC thread in a few years. I can start one, only I can't judge responses because I actually don't know the answer. :)
    I was looking upwards under the rear of my 2010. Hard to see in the space between the left rear wheel well and the bumper, concealed from below by the aero under cover ... but when I looked up through the cutout in the under cover where the tiedown bracket would come through ... I saw what looked like a small tank. It had a hose or two attached. That's sort of in the neighborhood of the fuel filler so I figured it might be the canister or something, but no, the canister/pump assembly is mounted right next to the fuel tank. This thing is something different.
    I didn't remember seeing anything like it in parts of the repair manual I had skimmed. I haven't been able to find anything like it in a few online dealer parts diagrams ... but maybe just because I don't know what to call it or where to look.
    Taking a second look at the New Car Features Manual, sure enough, it is there ... with no label and no description of what it's for. :)
    Anybody know?
    -Chap
  2. StarCaller
    StarCaller Senior Member
    1,272
    723
    Cedar Crest, NM, USA
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    Could it be a reservoir for brake fluid?
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    It's the E46 perpetual motion sensor for the emodium high torque eridium modulator. Can only be replaced by a certified mechanic specializing in high density mass repair.
  5. booke02
    391
    415
    Israel
  6. bisco
    51,280
    is it the exhaust heat coolant recovery system tank?
  7. Mendel Leisk
    40,719
    The lines from it look to be going to the charcoal canister. I looked a bit through the repair manual, no luck.
    Some sorta air reservoir, up high enuf to be above gasoline?
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    That's a peninsula off the coast of Florida.
    Everything in a diagram I can't identify is a peninsula off the coast of Florida.
  9. Montgomery
    2,254
    2,241
    Orange County, CA
    I remember seeing something like that once. I think it was when I was a kid, and I was about to get beat up by the neighborhood bully. Right before I was struck, I think he was holding something like that in his hand..................
  10. RRxing
    RRxing Senior Member
    2,533
    1,807
    NEPA
    (SWAG) Possibly part of the fuel sending unit.
  11. ChapmanF
    17,517
    Nerp ... sender is inside the tank with the fuel pump.
    Obviously part of the fuel system, since it's shown on that diagram, but ... ?
    I wonder if this will go unsolved until somebody who has the rear bumper off for any reason notices if that thing has a part number on it, and what that number comes up as online....
    -Chap
  12. RRxing
    2,533
    1,807
    NEPA
    (SWAG #2) Air Filter for the canister pump module air inlet line?
  13. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    Almost certainly must be inspected every 10,000 (miles or km, your choice) for 299.95 (dollars or Euros, your choice), only by a certified mechanic with experience in analysis of premium bullshitem.
    Montgomery likes this.
  14. bisco
    51,280
    is that what is making the small talk when you go out to the garage in the middle of the night?
  15. ChapmanF
    17,517
    A solid guess ... though your diagram here shows the filter right close to the fuel filler mouth, and I think that was where other diagrams I had looked at were showing it, too. I think the filter is the *4 in the diagram I posted (by memory ... I cropped the legend out of the screenshot).
    -Chap
  16. Nutstoyou
    Nutstoyou Junior Member
    34
    Southern California
    What you have here is a two part assembly consisting of the following items. Fretetisat and Kanuten Valve. This device circulates coolant thru the high speed door handles when the vehicle reaches speeds greater than 60 mph. This is to prevent the door handles from heating due to air friction, causing them to warp slightly and impact the aerodynamics of the car.
  17. StarCaller
    1,272
    723
    the high speed door handles are only standard on the premium models/
    mine's a two, so I have the basic door handles, nevertheless I have this part/
    BION
    StarCaller
  18. RRxing
    2,533
    1,807
    NEPA
    I wouldn't use these diagrams to determine actual locations. They aren't isometric drawings.
  19. Montgomery
    2,254
    2,241
    Orange County, CA
    I am laughing so hard I am crying.......... But, back to the original question, I have no idea what the heck it is.
  20. William Redoubt
    1,215
    1,165
    The Kanuten Valve. There's something very Canadian about that part.
