1. Offline
    ronhowell New Member
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    Can anyone tell me what the advantages are of having the 17" wheels available as an option on the new generation Prius?
    I hear that the mileage suffers to the tune of 2-3 MPG, the car is certainly heavier as a result of the heavier suspension, so where are the pros? Do the larger diameter wheels carry low profile tires; is the overall tire rolling radius higher than for the 15" wheels?
  2. Offline
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,975
    717
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Lower profile tires = better handing due to less sidewall flex. There's also an aesthetic appeal. If it were possible to have LRR tires on the 17", that' be the best of both worlds.
    I'm thinking some light 16" rims would be a fantastic compromise.
  3. Offline
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    If there's less sidewall flex in low profile tires than in regular tires, doesn't that mean that the rolling resistance should be lower, since less energy is being used to deform the tire while rolling?
    What am I missing here?
  4. Offline
    Husker4theSpurs New Member
    Apr 11, 2007
    Message Count:
    518
    32
    Lincoln, Nebraska
    Your Vehicle Year:
    Let's also mention ... THEY LOOK BETTER TO SOME PEOPLE!
  5. Offline
    Dec 8, 2003
    Message Count:
    4,975
    717
    Your Vehicle Year:
    The wider contact patch contributes to higher rolling resistance.
  6. Offline
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    Who in hell cares ... you don't spend your day staring at car tires do you!
  7. Offline
    Oct 4, 2007
    Message Count:
    677
    30
    Cypress, CA.
    Your Vehicle Year:
    So is the effective rolling radius of the 17" higher than for the 15" wheeled tire? Also is the LP tire capable of running at higher pressures? I would guess not, since the tendency for any tire under internal pressure is for the X-section to go circular.
  8. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Looks good (makes the Prius look a lot better even though it's the same car and only the wheels have changed) as well as better handling (wider tyres = more rubber = better grip plus as Rick said, less sidewall flex. The ride will be stiffer even if the suspension hasn't changed).
  9. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    if the car is designed for it, it should still ride well... i spent some time in new Avensis Wagon with 18" wheels (highest available factory package) and it went well over the big bumps we have around here... it might have been firmer overall than Prius, but it also lost a lot less composure over the bumps which actually made it feel better...
  10. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Yeah but note you're used to the firmer setup in Europe and your roads are a lot smoother and of better quality (maybe not in E. Europe but in the west for sure).
  11. Offline
    carz89 I study nuclear science...
    Apr 1, 2008
    Message Count:
    445
    44
    San Diego
    Your Vehicle Year:
    advantages: slightly better handling on dry pavement, better looking (according to some).
    disadvantages: more expensive (both the wheels and the tires), reduced mpg, slower acceleration, slightly poorer handling on wet pavement due to larger contact area between rubber and road; slightly reduced stopping power; reduced ride comfort with the shorter sidewalls
  12. Offline
    cycledrum I like Prius
    Apr 9, 2008
    Message Count:
    5,266
    432
    NorCal
    Your Vehicle Year:
    Less sidewall flex would be for more aggresive cornering; turning and sideloads, not rotational loads.
    I'm with HTMLspinner on 16" wheels. I think they would be a nice option. Slap on 205 width tires, and whatever profile for the correct diameter.
    Keep the 16" wheels from the Gen2 Touring for the Gen3. I like them even with the plastic wheel covers. They look like alloys.
  13. Offline
    Apr 9, 2008
    Message Count:
    5,266
    432
    NorCal
    Your Vehicle Year:
    17" wheels on the 2010 Prius ...
    That would be the $expensive$ car
  14. Offline
    Mike Dimmick New Member
    Aug 8, 2008
    Message Count:
    959
    226
    Reading, UK
    Your Vehicle Year:
    It's actually marginally smaller. A 195/65R15 tyre has an approximate rolling circumference of 1993.34mm (78.47"), while a 215/45R17 has a circumference of 1964.44mm (77.34"). The 15" has 807 revs per mile, the 17" 819 revs per mile.
    A 225 width tyre would be a better match at 1992.71mm (78.45"), still 807 revs per mile. However, that probably is too wide.
  15. Offline
    twilsonchicago New Member
    Aug 16, 2007
    Message Count:
    43
    Chicago, IL
    Your Vehicle Year:
    Hey, does anyone know if wheels that fit gen 2 will also properly fit gen 3's, and vice versa?
    Tim
  16. Offline
    spwolf New Member
    Sep 16, 2005
    Message Count:
    2,230
    156
    Eastern Europe
    trust me, you guys get better roads than us... they are not bad here as in some other countries, but we have few on our test drive routes where it gets pretty bumpy. As I said, Avensis with 18" wheels takes on those bumps better than 2nd Gen Prius.
  17. Offline
    Mar 8, 2008
    Message Count:
    9,152
    1,793
    Your Vehicle Year:
    Hi Tim,
    I don't believe that the 3G bolt pattern or wheel offset is known yet, so it would be difficult to answer your question accurately.
  18. Offline
    alz New Member
    May 29, 2006
    Message Count:
    North Carolina
    Your Vehicle Year:
    I feel silly asking this, but I can't seem to find it anywhere ... is there an actually photo comparison of the different wheel sizes on the 2010?
  19. Offline
    Apr 11, 2007
    Message Count:
    518
    32
    Lincoln, Nebraska
    Your Vehicle Year:
    I said SOME people, not all ... why do I have to think the way you do? Pious would fit you well. It's an option. Maybe we should have 8" wheels ... why do you need 15"
  20. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    haha ok.
    There isn't a side-by-side pic but there are photos of both wheels on different cars in the photo albums. Search for "2010 Prius Official Photos". should be on page 3.
Share This Page
