185/65r15??
Discussion in 'Prius c Accessories and Modifications' started by Maikan, Oct 22, 2014.
  1. Maikan
    Maikan Junior Member
    Hi! Can I put 185/65r15 winter tires instead of the 175/65r15 that comes with the Prius C?? I know that it will change the speedo but does it make anything else? I have perfectly good nokian tires of that size and I don't want to lose them.. They're pretty pricy! ;)
    Thanks a lot!!
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    They will fit.
  3. Maikan
    A tire dealer told me that it was possibly not good for the hybrid system to put another size of tire.. I really don't see why it would???
    Maybe he just wanted me to buy some from him ;)
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Take out the 'maybe' and you have it right
    The car WILL care if the tires are not all the same size.
    ztanos likes this.
  5. Maikan
    Don't you forget to add a NOT between will and care? ;)
  6. fuzzy1
    10,012
    No, he didn't. Significantly mismatched tires will confuse the ABS and VSC.
    ztanos likes this.
  7. Maikan
    I will not use mismatched tires.. I will use four 185/65r15 tires and I just wanted to know if they will fit and what kind of effect it would have on the car..I don't know where you guys got this idea...
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    They didn't say you were going to do it. Just mentioning it in case someone was thinking about only changing two tires. It'll work, but the car won't be happy.
  9. Manfred Melloh
    Manfred Melloh Junior Member
    Sydney AUSTRALIA
    Hi greetings from OZ.
    in oz the 185/60/15R are fitted as standard.
    It would be all OK.
    I will upgrade to 195/55/15R when my 185/55/15R ware
    Out.I have fitted 16.5" rims.
  10. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    16.5 rims????? Good luck with stretching the 15 inch tires to fit.
  11. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    I run 185-65-15 Continental True Contact during spring/summer/fall and 185-65-15 Bridgestone Blizzak tires in the winter on my C4. There is no problem in doing this.
