1998 Prius ABS On and brakes doesnt work
Discussion in 'Toyota Hybrids and EVs' started by prius1999, Feb 23, 2010.
  1. prius1999
    prius1999 New Member
    Hi guys
    I had this car since 3 years i guess, but yesterday when i turned it on it was beeping and i put it in reverse, then behold the brakes didnt work as usually, but when i pressed very hard it stopped slowly.
    I though brakes were stuff up, but i moved car up to big parking space and was keep going backward and forward, suddenly the beep stopped and the brakes worked as it should.
    But now today i though i will do the same thing, but the beep doesn't goes off and brakes doesn't work at the same time.
    When i turned on car, i can hear some sounds like tak tak below bonets.
    Any one know why brakes doesn't work.
    I have attached two photos as well, that's what it shows on screen..
    Any help would be appreciated, i have a manual in English, which is very small and doesn't have anything related to these signs.
    Thanks
  2. walterb
    walterb New Member
    Huntsville, TX
    2002 Prius
    I hope you had it tolled to a shop...... and fixed. it is obvious it needs attenetion
  3. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    just want to make sure that you are aware of a yahoo! group called Mk1_Prius. It is probably the largest collection of people exchanging information on how to keep The First Prius on the road
