2 cups of water leaked in backseat - any problem?
Discussion in 'Gen 3 Prius Main Forum' started by NMpics, Feb 12, 2014.
  1. NMpics
    NMpics Junior Member
    I have a 2012 Prius III. I put a 2 cup water bottle in the back seat and went to a meeting. When I came back I noticed almost all of the water bottle leaked into the seat cushion. The good news is that it leaked behind the driver's seat, not near the battery vent. Will I have any problems?
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Probably not with the battery, either 12v auxiliary or traction battery. However, possibly with mold or mildew.
    There are some instructions on how to remove the rear seat cushion in the Clazzio seat cover thread, I believe. I'd remove the seat and try to dry it out before it gets musty.
    SCH-I535
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The HV battery is directly behind the rear seat, most of it behind the driver half of the seat. As stated above I would try to remove the rear seat and check for any standing water around the battery housing.
  4. NMpics
    I figured out how to remove the back seat bottom cushion and there was a small pool of water on the battery housing. I live in high desert, so it should dry within a day. Thanks!
  5. xliderider
    7,848
    3,102
    Honolulu, HI
    Glad to hear that you live where it will be able to dry out. :)
    SCH-I535
  6. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Why not soak it up with a towel? The case is grounded so you are not going to get shocked.
  7. xliderider
    7,848
    3,102
    Honolulu, HI
    I'm sure the OP took care of the water in the car. The reference to letting it dry for a day was about the soaked seat cushion that was removed.
    SCH-I535
