2003 Dashboard, Horn, MFD Screen Problems P3002 & P1636
Discussion in 'Generation 1 Prius Discussion' started by slimfrancis, Feb 27, 2014.
  1. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    Hello Folks! I'm having weird issues with a 2003 Prius w/ Only 55k miles. I purchased this from a State auction and the car was missing an HV Battery and an A/C compressor. I bought a salvaged HV Battery that was measuring consistently across all 38 modules and put it in the car. I also put on an A/C compressor and replaced 3 blown 15A fuses. The car started and drove for a few minutes before the check engine light and triangle came up. The codes were P3002 & P1636 (HV ECU malfunction and Non-Communication with HV ECU).
    Before i swap out the HV ECU I'd like to explain a few other weird issues to see if all these symptoms are related??
    1. When key is turned to ACC airbag light goes on as it should.
    2. When key is turned to ON the MFD screen and dash DO NOT light up at all
    3. Car WILL start, horn beeps once and windshield wipers engage (just once) and dash and MFD screen will light as normal.
    The horn and wipers are the consistent odd behavior every time I started the car along with the MFD screen not lighting. I also notice when Scangauge is connected to the OBD port the dash is completely black and car won't start. I've only been able to connect the Scangauge after car is running.
    I was able to drive the car for about a 1/2 mile before the MFD screen turned grey and the car died. I disconnected the 12 volt battery to re-boot and the dash lights came up but the car wouldn't start. After one starting attempt the dash goes completely black again with no power. I've repeated this process numerous times (disconnecting the 12 volt) to see if I could start it but very odd things were happening each time such as: horn was stuck on blaring, the Park, Reverse, Neutral, Drive, Brake (PRNDB) lights on dash would stay lit for a few seconds after key was taken out of the ignition.
    Also, I've noticed some of the wiring in the ceiling seems to be missing. There are no wiring clips that connect to the map and dome lights.
    My question is:
    Do the dash light, MFD screen, and horn symptoms seem to be related to the HV ECU malfunction (P3002 & P1636)? Or does this seem to be an electrical problem that needs to be looked at? I've checked all the fuses and they seem to be fine. I'm not sure how to test the relays but I was thinking that may be a possibility also? Any help is greatly appreciated. Thanks Much!
  2. Patrick Wong
    18,199
    6,464
    1. What is the voltage across the 12V battery when IG-OFF now?
    2. If below 12.4V, first fully-charge the battery.
    3. When you can make the Prius READY, what is the voltage across the 12V battery?
    4. If less than 13.8V, check the DC/DC 100A fuse as that may be open.
    5. I suggest you obtain and download the electrical wiring diagram at techinfo.toyota.com so that you can study the diagram and figure out why the dashboard electrical systems that don't get power at IG-ON will get power when READY. You probably have more blown fuses or perhaps a failed relay.
  3. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    thanks patrick! is the dc/dc fuse the one located on the positive 12 volt terminal in trunk? if so it appears to be "good". i put a brand new 12 volt battery in and it measures 11.94. i've also tried using my booster pack as well. do you know how to test relays to see if they're good?
  4. Patrick Wong
    18,199
    6,464
    Hi Francis,
    1. No, the DC/DC fuse is going to be located up in the engine compartment, perhaps in the relay/fuse box near the inverter.
    2. Your 12V battery needs to be fully-charged now. Use a real battery charger.
    3. You need a 12V source to energize the relay coil, and an ohmmeter to measure resistance across the switched terminals. The resistance should not exceed 0.5 ohm after you account for resistance in the ohmmeter's test leads.
    slimfrancis likes this.
  5. usnavystgc
    3,159
    988
    Tucson, AZ
    Wow, this sounds like missing power to me as well. There are multiple problems. I would start with the dash power (because that's the most obvious "no power" indicator). But thats me, there is always more than one way to skin a cat.
  6. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    i just had the car running and driving again for a few minutes and again MFD goes grey and car shuts down. if the problem was a fuse or relay wouldn't i NOT be able to keep starting and driving it? when a fuse or relay is BAD it's BAD right? it wouldn't be an intermittent problem (sometimes it works, sometimes it doesn't) should i just replace the HV ECU first and see if that solves my problems? or is the "no power" dash a separate problem?
  7. usnavystgc
    3,159
    988
    Tucson, AZ
    Its really so hard to tell. I see no harm in replacing the HV ECU if you have a known good one laying around (which I'm betting you do). The no dash problem doesn't appear to be intermittent to me, it appears that power is consistently lost after the car is operated. What I would do is get it to the loss of power and then troubleshoot from there (of course thats easy to say from here).
  8. Patrick Wong
    18,199
    6,464
    "No power" is a separate issue. The hybrid vehicle ECU will not affect this.
    You need to study the electrical wiring diagram that relates to one of the dashboard items that does not get power. It is certainly possible that one fuse is supposed to provide power during IG-ON while another provides power when READY.
    If that is beyond you, then you should seek professional help for this issue.
    It is certainly possible that if you figure out the power problems, then the hybrid vehicle ECU will work just fine. An ECU is the last thing you should change, not the first - unless you know the ECU was subject to damage - for example, if the passenger footwell area was flooded.
    slimfrancis and usnavystgc like this.
  9. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    i found the relay which controls the MFD screen in the drivers door fuse compartment. any ideas where the relay or fuse for the IG-ON is located?
  10. Patrick Wong
    18,199
    6,464
    You need to download the repair manual info, as I previously suggested. There are many fuses and relays that are involved in providing power when the car is IG-ON.
  11. yotatoter
    yotatoter Member
    161
    43
    Ohio
    2001 Prius
    I
    I am probably completely off base here,but it sounds like your HV ecu is toast.. I do not know if that would cause your other malfunctions or not.. Almost reminds me of an anti theft problem...
  12. Patrick Wong
    18,199
    6,464
    With any electronic system (like the Prius), if you are aware of any power supply issues, that is the first thing that you have to take care of. Only after you have correct and stable power, then you would address whatever other issues remain.
    It makes absolutely no sense to be replacing an ECU for communications issues, when you know that some systems are not receiving power at IG-ON. First, get all systems to power up at IG-ON. Then if the hybrid vehicle ECU still is logged as not communicating with the other ECUs, it would be reasonable to replace it.
    I recognize it may not be easy to resolve the power issues, but that really must be done first.
  13. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    i've had plenty of other gen 1. priuses with bad HV batteries and i've never NOT gotten any power to the dash in IG-ON mode. if my memory is correct i believe that even with a missing HV battery the dash should light up with the 12 volt aux battery. this leads me to think patrick is correct about correcting the power problem first. however, yotatoter may be onto something with the anti-theft issue. i have noticed the red blinking key light (next to cassette deck, i forgot the name of this) seems to be flashing sometimes and NOT flashing other times. also with the horn beeping and sometimes being stuck on. hmmm?
  14. Patrick Wong
    18,199
    6,464
    Well, since your OP says you can make the Prius READY and have actually driven the car around, I don't think that anti-theft is an issue. If you could not put the Prius into any mode besides IG-OFF, then the immobilizer ECU might be a concern.
  15. ChapmanF
    15,098
    The thing about this car is that we know for sure it's had electrical problems (witness the three fuses you replaced, they didn't blow for no reason) and we know for sure it's had electrical mods (as you observed about the roof harness) ... not necessarily in that order. Have you had much of a look up under the dash just to see what's in there?
    I agree with Patrick that it only makes sense to start with the wiring diagrams, pin down what you're really looking for, and systematically track it down. For example, a number of the things behaving weirdly are controlled by the Body ECU. Have you checked it for codes yet? A ScanGauge can't do it; Techstream can, or the Tc-to-CG jumper and counting door-light blinks. But I'd add that it wouldn't surprise me if you get the diagram, learn from it what all components are supposed to be where, and then you look and find some box that wasn't even mentioned, that turns out to be Joe's Fantastical Automatic Door Opener, Shift Handle Heater, and Bluetooth Windshield Wiper Control, perhaps expertly installed by Joe himself as a personal favor to the DPO ... in which case there might be a limit to how helpful advice from the rest of us, who might not even have a JFADOSHHBWWC, could turn out to be.
    -Chap
  16. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    chap, when you say the "body ecu" do you mean the main ecu under the glove box? i started digging into the fuse panel on the driver's side door but couldn't reach all of them so easily because i couldn't get the outer side grey plastic cover off from the rest of the dash. the fuses/relays a bit deeper inside i didn't access. (im sure i can figure it out by prying around a lil longer) i located the MFD display relay and the one underneath it (not sure what that one was?) that's why i need the diagram.... WITHOUT having the wiring diagram would you start by pulling and testing every relay you see? i don't know why but i like to learn the hard way (also i hate giving toyota any more of my money. haha!)
    patrick, at "techinfo.toyota.com" is the wiring diagram available within the standard $15 for 2 days package? or do i need to download the professional diagnostic package for $55?
  17. Patrick Wong
    18,199
    6,464
    Yes, you should be able to download the electrical wiring diagram for the normal $15 subscriber fee.
    You'll also be able to identify where the various ECUs are located when you have access to the repair manual.
    Suppose the MFD is one of the units that does not get power at ACC-ON but gets it when READY. The wiring diagram would point you to the 15A DOME fuse.
  18. ChapmanF
    15,098
    That's a trick question, right? WITHOUT having the wiring diagram, I would start by ... getting the wiring diagram. I spend enough hours of my life reverse-engineering crappily documented stuff. If you're lucky enough to own something as well and thoroughly explained as your Prius, it only makes sense to take advantage of all the work they put into making it clear for you.
    -Chap
  19. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    wow! what a wealth of information in the toyota techinfo wiring diagrams. do you guys know if i save these to my computer as pdf files will i be able to open them for future reference at any time or will i only be able to open and view my saved pdf files for the 2 day period? i'm going to try and save as much of the info as i can. thanks!
  20. Patrick Wong
    18,199
    6,464
    IF you can save the files as .pdf then they will be available on your computer as long as your hard disk does not crash.
