1. Offline
    philmcneal Taxi!
    Jan 16, 2006
    281
    Burnaby B.C
    Your Vehicle Year:
    this is a cut and paste from my ad from 2004 prius
    198,000 km
    new front brakes with machining the front rotors (8 months ago)
    new pcv valve (2 months ago)
    70% tire life left (all seasons goodyear allegra more than 6 mm tread depth)
    new spark plugs NGK idrium good for 192,000 km (6 months ago)
    new valve cover gasket (2 months ago)
    new front shocks (4 months ago)
    needs a detailing service however, can be negoiated with the price
    taxi color (blue body with white top)
    comes with 12 case of 0w-20 oil Toyota brand (currently the car is using Toyota Full Synthetic 5w-30)
    type WS fluid changed less than 3 months ago (I change it every year even though Toyota says its good for 96,000 km... yeah right!)
    inverter coolant and engine coolant changed less than 2 months ago I used Toyota Super Long Lasting Coolant, good for at least 120,000 km + (service interval calls for 192,000 km first change but who believes in long life coolant?)
    new engine belt installed less than 2 months ago
    new 12 volt battery installed (12.7 volts before I installed it, 2 months ago)
    i used to work at toyota dealership so i hooked my car up fat, email me if interested, easily can get over 50 mpg us (4.7L/100km) if your not a noobie at hypermiling
    more info at http://www.canada.com/vancouversun/news/westcoastnews/story.html?id=c9eeba58-4dfe-45cb-b991-13f0ad979656
    i sell cuz im moving to toronto, i got cars there already waiting for me (aka bimmer 3 series yo!!)
    I took such good care of my Prius, honestly if I had to choose I'd ship it over to where I'm moving to, however, my family has already cars for me so really it'll be a moot point. A lot of the things I changed was for preventative maintainence and is not to suggest things kept breaking on my car, actually the only thing that went bad was the left front strut was leaking, so I replaced both, this car is good to go! I reduced the price, and as always or best offer and if you really want i can pull the service history on the car since I got the infostream.toyota.ca hookup Trust me this Prius will save someone a lot of gas looking for a good A to B car, everything on this car works and I recharged the A/C last summer. Also I found out Toyota plans to still sell my current generation model even though the 2010 Prius is a whole new design to compete agaist the Honda Insight hybrid, in terms of value for the consumer (classic bodystyle or new). SO you know Toyota will always support my model with updated parts, cheaper HV batteries replacements and what not. I used a scangauge II to measure battery voltage for the high voltage battery, and it swings between 190 volts all the way to 270 when under heavy regeneration braking, so you know this HV battery is not dying anytime soon. Toyota done a fanastic job trying to claim that the HV battery will last the lifetime of the car. And for kicks the EV button mode is installed as well! Plus CANVIEW for the curious email me
    car also had 4 window visors that the person can install themselfs using traditional 3m tape.
    email contact information can be found in the craiglist ad, thank you for reading.
Share This Page
