2004 Prius Warning LIght and Engine lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by doomteam1, Mar 1, 2013.
  1. doomteam1
    doomteam1 Junior Member
    32
    Highland, Ca
    Hello, I was driving last night and my car Triangle Warning Light and Check Engine Light Went on along with on the nav screen a car with a ! mark in it came on. On The info screen the battery level was changing fast from fully charged to just about empty. The car lost almost all power going about 42 miles an hour. I was able to pull to the side and i waited 10 mins then tried to turn the car on again. I was able to drive home and the warning lights were still on but at least my car had power. Does anyone know what could possible be wrong?
  2. Patrick Wong
    18,198
    6,464
    Your car's hybrid drivetrain is impaired and you will need to seek help from your local Toyota dealer's service dept or a competent independent specializing in hybrids. The problem might be a failed traction battery, inverter, or transaxle.
    xpcman likes this.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. doomteam1
    32
    Highland, Ca
    I just got the car 2 months ago, is there a way i can check to see if it was done on the car?
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  6. doomteam1
    32
    Highland, Ca
    There are about 113k miles on it give or take a few miles.
  7. doomteam1
    32
    Highland, Ca
    Well, i replaced the 12volt battery with an optima from auto zone everything went back to normal. So i drove about 100miles to the beach and the car gave out on the ride back. I had to have the car towed to a toyota dealership and they told me that the 12volt battery isn't compatible with prius and it shouldn't have been sold as a compatible battery. So i am having them put their battery in and they also told me that the water pump is cracked. Aparently the previous owner had the warranty done but the warranty isn't transferable so i am having to pay for that.
    The lights that lit up on the car are the
    VSC Light
    The ((!)) Light
    Check Engine Light
    and the Master /!\ light
    I will update when i get the car and drive around alittle more.
  8. Patrick Wong
    18,198
    6,464
    The Optima is not the cause of your car's problem.
    Which "water pump" are you referring to?
    If the inverter coolant pump had failed, that would cause the DC/DC converter within the inverter to overheat and stop working. That failure would mean the 12V battery no longer is being charged. As the 12V battery voltage drops down, that would cause the warning lights and the car stalling upon your return from the beach.
  9. doomteam1
    32
    Highland, Ca
    In the invoice that they gave me it says
    FP-Number
    16100-29157-83 Pump Assy , Water
    Price $95.24
    It says its the engine water pump.
    Also they are telling me that my Transmission Fluid needs to be exchanged which is $205.
    The 12volt battery was $203.02
    The Drive belt is cracked and damaged which is $28.36
    and labor for it all was $466.43
    For a grand total of $837.57
    The car seems to be running good now, just the price was so high.
  10. doomteam1
    32
    Highland, Ca
    Well the car did the same thing yesterday lost power lights went on, same lights. And i had to have it towed. They tow truck company towed my car a few inches while it had its brake on, and then again tried to tow it with it off, he turned it off and put the brake on.
    Now they are saying the reason my car is messing up is because of the generation system. They said it does not have an alternator it has a generation system.
  11. doomteam1
    32
    Highland, Ca
    well i just got a call from them they are saying the transmission might be bad and to test it they are getting a part from toyota
  12. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
  13. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Yes, take it some place else.
  14. doomteam1
    32
    Highland, Ca
    Thanks but that is 70miles away. The car doesn't even run right now so i wouldn't be able to.
    Ok, i will no longer post on this forum. I didn't know i was being a nucince since I only posted on my topic. This will be my last post for this website
  15. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I meant take the car some place else not u.
    kenoarto likes this.
  16. doomteam1
    32
    Highland, Ca
    They called me today, they now said they have no clue what is going on that toyota does not support any cars with more then 100k miles, and that i should be lucky that they are helping me.
    They said they would need to drive my car 200miles to find out what is wrong.
    I called their main office and have now filled a complaint against them.
  17. boppo
    boppo Active Member
    799
    138
    Owego, NY
    WOW, u got to find a better dealer.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
  19. doomteam1
    32
    Highland, Ca
    Its an official toyota dealer. I'm wondering if i can have them tow it to another toyota dealer to deal with this.
  20. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    359
    Fixed one yesterday which was misdiagnosed by a dealer and came from 98 miles away. Details coming soon to the water pump thread.
    Avi
