1. Offline
    Cloaked New Member
    Start a Conversation
    Sep 3, 2006
    Question?
    I own a 2005 Prius, and it has the standard screen for climate/audio/information (4 button system).
    I noticed that Toyota does NOT do any after sales upgrades for a Navigation system. Called them today and the parts department verified this can't be done (seems foolish since Toyota could make some money off these options...).
    If I can find a OEM navigation system to install in the Prius, can it be slapped in? Or is there some wiring that would be mising from the original manufacturing of the vehicle?
    I know I would need the navigation system, voice recognition box and possibly the steering wheel button.
    If I found these items, can it be done?
    Thanks for any input!
  2. Offline
    hdrygas New Member
    May 22, 2004
    3,650
    Olympia Wa
    Your Vehicle Year:
    I guess it could be done but it will not be easy. There are several sensors that you will need. The wireing harness is different. There are a few ECU's that are different. I can be done but it would take a lot of knowledge. I would go for an after market solution, if I were you.
  3. Offline
    sl7vk Member
    Jul 3, 2006
    516
    Salt Lake City
    Your Vehicle Year:
  4. Offline
    newkbomb New Member
    Aug 19, 2006
    22
    <div class='quotetop'>QUOTE(hdrygas @ Sep 5 2006, 09:53 PM) [snapback]314948[/snapback]</div>
    I would just get a Tom-Tom or Garmin... They are very small these days and mobile! I'm assuming it would be way cheaper than trying to integrate one into your MFD.
  5. Offline
    Apr 23, 2005
    3,841
    Your Vehicle Year:
    There are also some aftermarket systems that can be built in. They replace the radio (actually they become the radio, CD, XM) and the screen pulls out for use and retracts when not needed.
  6. Offline
    rich502 New Member
    Sep 6, 2006
    For the 2005 Prius Nav system, regular upgrades are important. I have a 2005 Prius with a Nav upgrade from Jan 2005. I called my dealer to see if an upgrade was avaialable, and they weren't sure.
    Does anyone know if a later Nav upgrade for the 2005 Prius is available. Was there a Jan 2006 upgrade and do you think there will be a Jan 2007 upgrade. The Jan 2005 upgrade cost $275. What do you think future upgrades will cost?
    Thanks!
    Rich
  7. Offline
    Apr 23, 2005
    3,841
    Your Vehicle Year:
    <div class='quotetop'>QUOTE(rich502 @ Sep 6 2006, 05:27 PM) [snapback]315508[/snapback]</div>
    What version number are you talking about? The latest is 5.1, I believe.
  8. Offline
    Feb 25, 2004
    14,314
    1,335
    Spokane, WA
    Your Vehicle Year:
    Rather than trying to install a system that would put NAV onto your present MFD, get a Garmin StreetPilot. It sits on your dashboard and puts the NAV screen right in your field of view (but below the bottom of the windshield) so that you can see it without looking way off to the side. I find this set-up very good. It plugs into the cigarette lighter and it gives voice directions as well as text on the screen, and of course shows you a map of where you are with arrows indicating turns.
    One very high-end model can connect to your speed sensor for when you lose the satellites, but I don't think that's worth the extra cost.
    Another high-end feature on some is traffic info, capable (supposedly) of routing around traffic jams, but note that this is only available (for a fee) in a very few very large metropolitan areas.
  9. Offline
    xbdude opticat
    Oct 14, 2005
    168
    North Central Florida
    Your Vehicle Year:
    I purchased a Garmin NUVI 350 GPS from "Abe's of Maine" over the web. It is GREAT, and mounts easily. It can be transferred to my Tacoma when needed. The touch screen and display resolution is fantastic.
Share This Page
