2005 Prius 12V Battery Questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Princess9483, Feb 16, 2014.
  1. Princess9483
    Princess9483 Junior Member
    36
    St. Petersburg, FL
    Hi all! I bought my new-to-me 2005 Prius with 56k miles in July. I initially was concerned about my mpg but shrugged it off due to me only driving a mile or two at a time. Now that I am driving 10 miles and up everyday I am starting to notice that my mpg is not where it should be. So I did the battery test and got these three numbers, 12.3, 11.8, 14.1. I also checked the tires and noticed that they were really low, around 25 psi, so I will fix that immediately. My question is since these numbers are just below the minimum should I replace the battery now? Thanks in advance!
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    The numbers for your battery could be interpreted a couple of different ways.
    If they come from the MFD test when the car has set over night, the battery is getting weak. Possibly need replacing before next winter.
    On the other hand if the test was ran just after you shut down the Prius, then the battery probably needs to be replaced ASAP.
    Low air pressure in the tires would definitely account for the low MPG, plus short trips don't help either.
    Best of luck to you!
  3. Princess9483
    36
    St. Petersburg, FL
    Thank you! Yes the Prius has sat overnight.
  4. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Given that he lives in Florida, summer is a LOT more stressful on the battery than winter.
    Since the battery is about 7 years old, I suggest replacing it soon.
    The numbers definitely indicate a weak battery........or a meter that is out of calibration.
  5. Princess9483
    36
    St. Petersburg, FL
    Okay. Should I buy the Optima or Toyota OEM?
  6. dorunron
    3,318
    1,103
    Houston, TX
    I would say you are in need of replacement. I would imagine you are on the second battery. A 2005 Prius battery would be approximately nine to ten years of age if it were original. Most don't last much longer than five or six years in a Prius.
    It would be a good idea to replace it before it fails. The Prius really doesn't give a warning like slow cranking on other car's. Most of the time when they fail, you are pretty much dead in the water and sometimes can't even jump them.
    One hour job if you are mechanically inclined. Plenty of info here on Prius Chat on how to change it. Link in my signature below from when I did mine - Post #8 in that string.
  7. dorunron
    3,318
    1,103
    Houston, TX
    Plenty of opinions on that one. And they go both ways. When I did ours, I went with the battery from Toyota. Too soon to tell on it, but so far so good. At least mine was fully charged when I bought it. Have seen a lot of posts recently about Optima's sitting on shelves for long periods of time before being sold and will not charge back up fully. FWIW, I am a old school type. Daddy taught me that original equipment is best and what is designed for that application. Other's will disagree and say that aftermarket at times is advanced. .
    Remember opinion are just that, opinions. Everyone has one. It is really up to you what you buy. Both batteries will do the job as long as you get the right one.
  8. Princess9483
    36
    St. Petersburg, FL
    Thanks dorunron! I have no idea if this is the 1st or 2nd battery, there is no service history of it and most of the paperwork is accounted for. I will give my mechanic a call in the morn since I don't own any socket wrenches and depending on his installation cost I will decide on OEM or Optima since Advance Auto Parts offer free installation. Will keep you in the loop, thanks guys!
    P.S. Easy Rider, I'm a she, lol.
  9. bisco
    48,945
    if your curious, the label has a date code which can be interpreted by some here.
  10. dorunron
    3,318
    1,103
    Houston, TX
    I would verify with Advance Auto Parts that they will do a Prius 12 volt for free. It is not the easiest battery in the world to put in. But it can be done by anyone including you if you have the tools. Doesn't take a lot of tools either.
    Before you pay someone to put it in, take the time to watch this video.
    Best of luck to you and let us know how it is all works out in the end.
  11. Princess9483
    36
    St. Petersburg, FL
    Thanks dorunron! I have contacted my local Advance store and they confirmed the free installation but I decided to buy the optima battery and a socket wrench set from Amazon and install it myself, will save about $20 plus I will have a new tool set for later use, like installing a new seat belt that my dog ate :confused:. Will let you know how it turns out!
  12. Easy Rider
    982
    210
    N. Central Florida
    In my opinion, neither.
    You need an AGM style battery from a "name brand" company.
    I've never had a problem with an Interstate battery; even the Diehards from Sears seem to be good.
    If it would be more convenient for some reason, go for the OEM; I think the Optima's are over priced and over-hyped but that is just a gut feeling.
    Britprius likes this.
  13. Easy Rider
    982
    210
    N. Central Florida
    Sorry. I'm old enough that "he" was the accepted generic term when one didn't really know the gender.
    In this case, I should have known better.......given the screen name.
  14. Easy Rider
    982
    210
    N. Central Florida
    Please do.
    There are some safety concerns with both operations.
    With the battery, disconnect the NEGATIVE post first and keep it disconnected until ALL of the other work is done and then re-connect it last.
    I'm not sure I'd recommend anybody do their own seatbelts these days.
    Most have a "pre-tensioner" which is operated by a blank gun shell.....really.
    Good luck. Hope it all goes well.
  15. Patrick Wong
    18,198
    6,464
    I hope that you bought high quality tools. The sockets should be six-point (not 12-point) if you are going to do work on the seat belt fasteners which are torqued pretty tight, 31 ft.-lb. A cheap 12-point socket may round off the hex edges of the nut.
    The 12V battery installation will require box/open end wrenches as well as socket wrenches. You'll use the 10, 12 and possibly 14 mm sizes. Good luck with that.
  16. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    I highly recommend the Exide AGM or OEM. I am in Tampa, I have a wholesale account and can pick either one up for you if you like and install it for you no charge.
    PM if you need help.
  17. Princess9483
    36
    St. Petersburg, FL
    Hi guys! Thought I would give an update. So TampaPrius.com helped me out and put the new battery in, an Exide AGM, and come to find out there was an Optima in there with a manufactory date of 6/13. We were both shocked! So I will give them a call and see what solutions they have for me since the battery is not even a year old. My mpg has been increasing, idk if it is due to the new battery or if it is me slowing down and watching the moniter closely, but I am now averaging 42 MPG from 35 MPG, WOOHOO!!! I have noticed that short trips kill my mpg but I live in Florida and walking a couple of miles just is not an option, i.e. a couple of weeks ago I was a witness to a car vs bicycle accident where the cyclist flew 10ft across the hood. I think I was more scared than he was, lol. I thank all of you for your support and advice. I have found a new local go to for my Prius problems, he even helped with my rattling spoiler, and next up is my seatbelt that my loveable Goldendoodle decided to decorate for me with his teeth, lol. Thanks TampaPrius.com!
  18. dorunron
    3,318
    1,103
    Houston, TX
    Princess9483,
    If you have access to a 110 volt outlet whereas you could plug in a battery charger to charge your battery in your Prius, I would suggest to you to invest in a good "smart charger" that is designed for AGM type batteries. If you keep your 12 volt fully charged it will last you a lot longer than simply relying on the charging system that is built into the Prius.
    Best of luck to you.
  19. uart
    uart Senior Member
    4,215
    1,200
    Australia
    To be honest I don't think those numbers are low enough to cause any serious problem or any noticeable reduction in MPG. Any increase that you're noticing with the new battery is probably due to one of either changed driving habits (thinking more about fuel economy) or driving conditions or just random variations.
  20. Easy Rider
    982
    210
    N. Central Florida
    Those numbers ARE indicative of a battery that is getting weak.
    Whether or not it was bad enough to cause engine problems is a matter of speculation but others HAVE reported that weak batteries have caused engine faults and so did he. What's the point of questioning his reported results now ??
