2005 prius - how much oil does it hold?
Discussion in 'Gen 2 Prius Technical Discussion' started by newbie, Aug 8, 2006.
  1. newbie
    newbie Junior Member
    24
    Maryland
    Exactly how much oil needs to be replaced when changing the oil? I read 3.7 qts, but want to be sure.
    Thanks!
  2. nmrickie
    nmrickie Member
    200
    New Mexico
    I use 3.5 quarts, puts it just below the "full" mark.
  3. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    With my 2004, 3.3 litres will put the oil on the Full dot.
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I refill with exactly 3.1 quarts on the nose.
    Who wants to go for 2.9?
  5. richard schumacher
    7,663
    1,038
    United States
    3 quart bottles is most convenient. This puts the level near the halfway point, which is perfectly fine.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    You've asked two different questions:
    "How much does it hold" is the post title--that answer is 3.9 quarts. However, probably due to residual oil in the system, putting that much in will almost always put you over the 'max' mark on the dipstick.
    3 to 3.5 quarts is good for oil changes. As suggested, put in 3 quarts at the dealer and top off, if necessary, when you get home.
