2005 Prius not ready
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Hammer, Aug 23, 2014.
  1. Michael Hammer
    Michael Hammer Junior Member
    36
    As the title says have a Prius without the smart key and the car wont go into ready mode and the lights stay on all except the triangle . I ran the tech software and no current codes were listed although immobilized said it was not set . Could it be the battery in the key fob preventing the car from going into ready mode ?
    48,946
    if you have to insert the fob into the dash, it don't matter if the battery is dead. might be your 12 volt battery.
  3. Michael Hammer
    36
    Checked the 12 volt settings looked good .
  4. JC91006
    16,470
    8,383
    What are you using to check for codes? What's the voltage reading on your 12v?
  5. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Are you stepping on the brake pedal and pressing the power button to start? Have someone check to see if the brake lights are coming on. If there is a problem with the brake pedal switch, the car senses that you are not stepping on the brake pedal and goes into acc. mode only.
  6. JC91006
    16,470
    8,383
    If you messed with the hybrid battery and the orange interlock, make sure that interlock is in place and pushed down in the lock position
  7. Michael Hammer
    36
    So were saying its definitely not the key fob . It might be the brake pedal switch I will try that .
  8. JC91006
    16,470
    8,383
    If it's the switch, it would have a DTC code
  9. Michael Hammer
    36
    It did have a dtc code but not current but in the past and it happened to be about the brakes .
  10. JC91006
    16,470
    8,383
    The brake switch error would light up the red triangle
  11. Michael Hammer
    36
    Oh theres no red triangle . Just all the other lights are on .
  12. JC91006
    16,470
    8,383
    Try to Disconnect the 12v battery negative to reset the car. It should allow you to start after it resets
