2005 Prius replace Auxillary battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dores04, Jun 13, 2010.
  1. dores04
    dores04 New Member
    We need to replace the 12v battery for our 2005 Prius but no one seems to have any in stock but the Toyota dealer - has anyone out there been able to get a battery cheaper than from the dealer? If so where and were they able to install it? We live in Fairfax, VA but I was also thinking about ordering the battery online
  2. Patrick Wong
    16,089
    4,122
    I doubt that you will be able to order the 12V battery from an online Toyota dealer parts dept due to concerns about shipping hazardous material. Battery MSRP is $139.
    The battery is AGM, hence it should have little or no free electrolyte inside, and is packed in so much shipping material it is a bit ridiculous. Nevertheless I believe that most dealers selling parts over the web will not ship the battery.
  3. dores04
    dores04 New Member
    My husband went to Auto Zone and they didn't have the battery at the store, but when I went on line it looked like I could order one from their on-line store and have it delivered to the store and have them install it. But when my husband was at Auto Zone they just said they didn't have any and gave him the impression that they didn't deal in batteries for Prius'. That's why I was wondering if anyone had any luck getting a replacement anywhere except Toyota
  4. Patrick Wong
    16,089
    4,122
    The Prius 12V battery has non-standard battery terminals that are much smaller in diameter as compared to a regular 12V battery. You will not be able to find an exact replacement battery anywhere (in the US) other than at a Toyota dealer.
    If your husband is willing to mess around with installing replacement battery connectors, then a yellow-top Optima battery of the correct physical size could be considered as an alternative. However the total cost including connectors will probably be greater than $139.
    For example, see: http://www.elearnaid.com/12vo1topraub.html
  5. vertex
    vertex Active Member
    669
    120
    new york
  6. jreed
    jreed Member
    84
    53
    North Carolina
    I just replaced the original battery in my base 2006 Prius (98K miles) with the Optima 51 Yellow Top and the elearnaid adapter kit. The elearnaid kit came with everything needed and was shipped in 3 days :). It cost $16 more than the dealer battery (which was quoted as $139 + tax = $149). The kit came with detailed instructions including a list of recommended tools, which was very helpful.
    My mileage was 52-54 mpg last week (with the original battery reading 11.9 - 12.0 V in accessory on mode) and was 54 yesterday with the Yellow Top (reading 12.6 - 12.9 V in acc mode).
    So far, it's working well and I'm glad I chose the Optima.
  7. kenoarto
    kenoarto Active Member
    106
    Chicago, IL
    There's almost always a 20% off parts coupon available at my two local dealers. After trying to get one installed by CarX (and failed due to the idiots swearing they had the proper size and had done it many time before on a Prius II). I eneded dong the install myself (dealers wanted $100). Took me 15 easy minutes (not at all the usual a nasty job, because the battery is perfectly clean,inside the car, in the right rear trunk area).
  8. Beach-Prius
    Beach-Prius Junior Member
    Cardiff-by-the-Sea, CA
    Really dumb question. How do you know when it is time to replace the battery? Is it like on a regular car where the internal combustion engine will not start?
  9. Silver bullit
    Silver bullit Right Lane Cruiser
    606
    201
    San Diego, California
    I'm sure other more knowledgable people can answer this for you. I don't think the Prius works like this. Greetings from Vista! Heading out to Cardiff beach with my dog today.
  10. andyprius
    andyprius Senior Member
    2,212
    164
    Sacramento, California.
    Almost every battery I have ever tested, later proved to me that it was going to fail IF it only read the rated voltage. ie: 12 volts. With a flashlight it is not so critical but a car it definitely is.
    :D
  11. donee
    donee New Member
    2,958
    191
    Chicagoland
    Hi All,
    The battery that Elearn-aid sells is also sold at Advance Auto. It took some on-line detective work to figure that out. I had bought the adapter kit some months before, from Elearn-aid, to be prepared. Then found one of the local Advance auto parts stores with a newer stock battery. It was definately more than $135, altogether, however. But, I had it done in a few hours on a weekend.....
  12. richard schumacher
    7,652
    904
    United States
    Eventually, but first you'll most likely get any number of random symptoms of other phantom problems. The two things that will *not* happen are the rr-rr-rr of slow cranking or the click-click that happen with conventional drive cars; this is because the Prius 12V battery does not directly crank the engine.
    If the battery is more than 4 or 5 years, or if it's ever been drained for whatever reason, test it. E-Z do-it-yourself procedures are given here:
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
  13. Silver bullit
    606
    201
    The voltage on my scanguage usually reads 13.2 volts. Would the scanguage show the voltage dropping to 12 volts indicating the battery needs to be replaced?
  14. jdenenberg
    jdenenberg EE Professor
    2,856
    854
    Trumbull, CT
    In "Ready Mode" (ie when you are driving your Prius) the voltage should read about 13.8 volts (the inverter is charging the 12v battery). When in ACC (Power on without touching the brake) the voltage should read about 12.5. Your 13.2v is a strange reading. Use your MFD in maintenance mode or a digital voltmeter to read the battery voltage directly.
    JeffD
  15. andyprius
    2,212
    164
    I am guessing that you are using the scanguage in ready mode, if so, you are looking at charge rate. Use either the self check on the car, or buy a multi-meter, digitals are available for less than $10.00. Incidently no instrument drops voltage, they read voltage. Voltage is only dropped across a load ( a resistor, lamp, radio, etc. ) In the quiessent state, that is no load, not in ready, the battery must read something more than 12 volts.
