1. Offline
    Joe1987 Cheyenne Joe
    Start a Conversation
    Apr 18, 2009
    26
    Your Vehicle Year:
    Recently, my 2006 has been showing a decline in MPGs. I purchased a K&N filter several months ago hoping that it would help in getting better MPGs. I also watch my tire's air pressure, but the MPGs still fall off. I used to get around 43mpg in town and 45 to 47 on the highway. Now, I'm lucky to get 39mpg no matter where I'm driving.
    I've been thinking of changing the spark plugs since I'm sort of grasping at straws. Also, someone told me that the older the battery pack (NHW20) gets the less MPGs I can expect. Maybe true maybe not! My Prius has a little over 60,000 miles on it and it shouldn't be loosing MPGs.
    Anyone have any thoughts? Should I think about a new battery pack?
    Joe1987
  2. Offline
    josh2008 Hyundai Tech
    Sep 2, 2008
    363
    132
    Princeton, WV
    Your Vehicle Year:
    Been using a/c more frequently lately? A/c puts a pretty significant drain on the hybrid system.
  3. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Yes, I have but the mileage I mentioned was with the AC on, all the time. I live in Florida!
  4. Online
    Apr 14, 2009
    5,771
    1,591
    Greenwood MS USA
    Your Vehicle Year:
  5. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
  6. Online
    Apr 14, 2009
    5,771
    1,591
    Greenwood MS USA
    Your Vehicle Year:
    Great, that may rule out some 12 volt battery failure modes that prevent it from getting to 12 volts and cause excessive recharging.
    A second 'common' issue is a dirty throttle body.
    TB cleaning
  7. Online
    uart Senior Member
    Sep 7, 2009
    2,765
    476
    Australia
    Your Vehicle Year:
    Any other changes recently? Tires in particular.
  8. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    No, same tires that came with the car. I purchased the car in April 2009 with 36,000 miles on it. No changes to the car.
  9. Offline
    wjtracy Senior Member
    Sep 19, 2006
    2,516
    313
    NOVA
    Your Vehicle Year:
    Usually in summer MPG actually improves. On the tires, are you saying normal Prius tires such as OEM GY Integrity or did prior owner make a tire change? Did you go with Optima battery replacement or Toyota? Of course short trips take a toll on average MPG. Make sure your recall work esp. inverter coolant pump replacement has been completed.
  10. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Thanks for your response.
    Shortly after I purchased the car (April 2009) the coolant pump went out. Thank goodness it was under warranty and the dealer replaced the pump while letting me use a loaner. For whatever reason, it took a month for them to get a pump.
    The tires that came with the car are Bridgestone Signia SE 200, the size is D186/65 B15. I hope this is the information for which you're looking. As for the battery, I purchased it from the same Toyota dealer that sold me the car. I checked it and it's holding a charge.
    Now for the throttle body; is there any kind of spray I can use to clean the TB without having to tear it apart? I'm looking for a quick cleaning solution.
    Joe1987
  11. Offline
    Sep 19, 2006
    2,516
    313
    NOVA
    Your Vehicle Year:
    Usually in summer MPG actually improves. On the tires, are you saying normal Prius tires such as OEM GY Integrities or the
    Re: Tires - I am not familiar with those Bridgestone's as a typical Prius tire , so I hope someone can say if that is valid tire for Prius. Goodyear Integrity was probably what they started out with from Toyota (at least for my 2006 it was).
    Re: Water pump- well Prius has a number of pumps. The main water (coolant) pump often leaks and many have replaced it under extended warranty. Then there is the inverter coolant pump that was a recall item for 2006 models. Yours is presumably fixed already, but if not could be reason for low MPG. So if you have not done so already, you need to check that your vehicle recalls are up to date.
  12. Online
    Apr 14, 2009
    5,771
    1,591
    Greenwood MS USA
    Your Vehicle Year:
    D186/65 B15
    A P at the front means a passenger car, no idea what a D means
    P: Passenger Car
    LT: Light Truck
    ST: Special Trailer
    T: Temporary (restricted usage for "Space-Saver" spare wheels)
    I am guessing the 186 is a typo for 185, I have never seen a tire width not divisible by 5
    65 the tire is 65% as tall as it is wide, very common.
    B would mean it is Bias Ply, a common tire type in the 1970s, replaced by radials almost universally, today
    B: bias belt (where the sidewalls are the same material as the tread, leading to a rigid ride)
    D: diagonal
    R: radial
    15 is the wheel diameter.
    If it is a D185/65 B15 it is a very poor tire.
    Tire code - Wikipedia, the free encyclopedia
    cwerdna and wjtracy like this.
  13. Offline
    Sep 19, 2006
    2,516
    313
    NOVA
    Your Vehicle Year:
    Joe by the way, this makes me wonder about the dealer.
    Hard to imagine how it could take a month to replace coolant pump.
    If they were not able to give you a good reason, then it is doubly suspicious.
  14. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    For what's worth, I was told that Toyota was in the process of "re-designing" the pump because they had several pump failures. The pump had to be shipped from Japan. I had a new loaner '09 Prius to drive for the month so I really wasn't inconvenienced.
  15. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    If I remember correctly, it was the pump that keeps the battery cool. Does that sound right?
  16. Online
    uart Senior Member
    Sep 7, 2009
    2,765
    476
    Australia
    Your Vehicle Year:
    No, there isn't a pump that keeps the battery cool, there is just a blower (air).
    You're probably thinking of the inverter cooling pump. It's sometimes also called the HV (high voltage) cooling pump which probably led to the confusion (even though the electronics it cools is nowhere near the actual HV battery).
  17. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Thanks, now I'm just showing my ignorance. Joe1987
  18. Offline
    Sep 19, 2006
    2,516
    313
    NOVA
    Your Vehicle Year:
    Joe your tires have been identified as a possible problem area.
  19. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    How so??? I checked my owner's manual and Google and neither recommended a particular brand or type. Joe1987
  20. Online
    Apr 14, 2009
    5,771
    1,591
    Greenwood MS USA
    Your Vehicle Year:
    185/65R15 is the correct size in the USA for a Gen 2 base Prius
    The correct type is LLR Low Rolling Resistance, so far as I know the only down side to not using LLR tires is reduced MPG.
Share This Page
