1. Offline
    Joe1987 Cheyenne Joe
    Start a Conversation
    Apr 18, 2009
    26
    Your Vehicle Year:
    Wow, thanks. I did not know about the LLR feature, but I will look into tires with that rating. Joe1987
  2. Offline
    Jon the Chief Jon the Chief
    Oct 13, 2007
    50
    Wolverhampton UK
    Your Vehicle Year:
    This is a post I put on the brake problem thread, you might look at this for you lost MPG
    What is the complete fix is to take the pads out and clean them up, clean up the shims and guide clips and put them back with fresh grease on the shims and guide clips.
    This will also get your fuel consumption back to what it should be.
    I had been getting only about 50-52 per UK gallon. (about 41-43 per US gallon)
    After I fixed the noisy brake I was getting 55-58 per UK gallon. (about 45-48 per US gallon)
    So I serviced the others pads, shims and guides as well.
    I am now back to my normal old 62 per UK gallon. (about 51 per US gallon)
    The job is not hard but hold the hex on the guide pin when undoing the front calliper bolts or you might damage the rubber covers.
    The rear callipers have only one bolt and they then swing up to and slide back off the other guide pin. Then it is just clean everything up and be carful to put it back in the same place it came from. I still have old fashioned brake grease in my tool box, but it seems like Toyota use high temperature anti-seize compound.
    Codyroo likes this.
  3. Offline
    Codyroo Senior Member
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    While replacing the tires with LRR tires will improve your overall MPG's, it doesn't address the issue that your current MPG's have dropped relative to previous fill-ups and the tires are unchanged.
    I'd be more interested in checking out the brake solution provided
  4. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Thanks for the hint. Although my brakes are working fine (with no noise), I will look into a brake cleaning soon.
    Joe1987
  5. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    Joe1987,
    Are you the only person who drives your car? Is it possible that another driver of your car might have knocked the tires out of alignment? I don't know if a bad alignment would explain the magnitude of the mileage drop, but it could explain the suddeness of it.
  6. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Thanks for the hint. My car is in the shop as I write this. I have a bent tie-rod that caused the right tire to dramatically lean outward. Both tie-rods are being replaced followed by a four wheel alignment. Hope this helps with the mileage problem.
    Joe1987
  7. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    I did a quick google search to find out causes for bent tie rods and effects. In one thread, a Jetta owner was estimating his MPG loss was around 3 - 5 mpgs. (which he thought was no big deal). Jeez! For a 30 mpg Jetta, that is 10 - 18%. For your car , this might mean a 4 - 6 mpg increase. I hope this resolves your MPG issue!
  8. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Hi, well I screwed up again! They replaced a bent strut, actually both struts were replaced. Sorry for the misinformation.
  9. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    I was looking up bent tie rods and bent struts (symptoms and causes). Seems that most people are concerned about brake shops ripping them off rather than the rods/struts (I'm guessing that a bent strut is an unusual circumstance). Hopefully you are at a shop you trust and they aren't trying to squeeze you for cash.
    But mostly, I hope this resolves your issue! Good luck and keep us updated! When you get your car, please fill it up and see if you notice any improvement in mileage over the next few days.
  10. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    Will do and thanks.
    Joe1987
  11. Offline
    backspinnn New Member
    Aug 8, 2012
    16
    McKinney, Texas
    Your Vehicle Year:
    My MPG suffered right before my traction battery died. I didn't realize until after the battery was replaced today that it had been rev'ing higher than normal when going up ramps to the interstate and small hills. Now that the battery was replaced, it is easy to pick out something was wrong.
  12. Offline
    cwerdna Senior Member
    Sep 4, 2005
    11,648
    1,658
    SF Bay Area, CA
    Your Vehicle Year:
    I suspect a whole bunch of typos. I was thinking, "holy crap! One can still buy bias tires?!?!?" I see Bridgestone Insignia SE200 which are radials and of type R.
    I've never heard of these tires and wouldn't be surprised if this is responsible for some mileage hit. No Priuses ever shipped w/these tires.
  13. Offline
    Apr 18, 2009
    26
    Your Vehicle Year:
    I just had a bent strut replaced (actually, both sides were replaced) and a four wheel alignment. To my amazement my on board computer just displayed 46.5 mpg. I haven't filled the tank to do a manual calculation, but I love what I saw. This is a rural type environment and not a heavily traveled city like New York, but I'll take it. Who would have thought that a bad alignment can cause that type of decline in mpg's?
    Joe1987
  14. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    Joe1987,
    Thank you very much for following up this post. I was hoping that the alignment/new struts would alleviate the worst of your MPG woes.
    Check your tire pressures as well. Likely the shop set the pressures at something akin to 33 - 35 PSI. If you pump up your tires to 40 - 42 PSI (42 PSI fronts/40 PSI rears, assuming 42 PSI doesn't exceed your upper pressure limit) you'll see more of an improvement in MPG's and greater tire life, as the higher pressures will minimize tire edge wear (a symptom of underinflated tires).
  15. Offline
    ErnieM New Member
    Aug 10, 2012
    Your Vehicle Year:
    Joe - I have a 2007 Prius and had been getting 52-53 mpg average. I just had a 50,000 mile service at the dealer and my gas use has gone to 45 mpg. I keep the tire pressure at 35 psi, Michelin tires(Harmony D185/65R15). I checked the oil level and it was above the full mark , about 40%. Another thing that I got from the web is fuel injector cleaner. I will try that.
    ErnieM
  16. Offline
    Oct 24, 2007
    1,686
    408
    Pleasanton, Ca
    Your Vehicle Year:
    ErnieM,
    The overfilled oil change = lower MPG is well documented on this site. I'd see how removing the excess oil impacts your MPG's prior to a fuel injector cleaner. Most gasolines have detergents in them that would seem to minimize the utility of fuel injector cleaners. That's not to say it won't make a difference, but I'd go after other low hanging fruit (overfilled oil, Tire Pressure) first.
    BTW, I don't think your tires are Low Rolling Resistance (LRR) tires.
    Harmony | Michelin Tires
    Michelin gives them a 6 out of 10 for fuel efficiency for tires of the same class.
  17. Offline
    uart Senior Member
    Sep 7, 2009
    2,753
    474
    Australia
    Your Vehicle Year:
    Hi Ernie. That's a major overfill on the oil. The dimples on the dipstick are spaced about 45mm, so 40% is about 18mm, that's nearly 3/4 of and inch! Overfilling the oil, especially by more than 1/2 an inch, is very bad. Yes it will decrease your MPG. Worse however it will cause your oil to splash and froth which may result in fouling of your intake/throttle body.
  18. Offline
    HaroldW Member
    Mar 17, 2012
    294
    31
    Grand Forks BC Canada
    Your Vehicle Year:
    There is a spray can for cleaning your throttle body. Most auto supply store will carry this cleaner. Do a search and you should come up with a blow by blow on how to clean your throttle body. H
  19. Online
    Ken S Member
    Jan 13, 2005
    180
    Delray Beach, Florida
    Your Vehicle Year:
    One thing I've learned about driving a Prius in Florida is that once the outside temperature gets to about 90+ the MPG drop substantially. I keep my A/C set to 77 and during the fall/winter I will get 45 - 47MPG on my daily commute. When the temperature increases (I keep my tire pressure at 42/40 and check it regularly) the MPG can drop as low as 40. I did all sorts of checks with a Toyota dealer and a trusted independent guy and nothing was coming up.
    As soon as it cooled down (high 70s) the MPG would go right back up. This has been the case for the past four years with no dramatic changes to the car...just regular maintenance, oil changes and new tires (which did drop mileage a bit for about two tanks).
    Highway mileage which isn't part of my regular commute has always been 40MPG (Avg 65 - 70 mph) not matter what the outside temperature is.
Share This Page
