2006 Prius needs new Battery pack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BiffPa, Dec 29, 2010.
  1. BiffPa
    BiffPa New Member
    Pennsylvania
    Just learned yesterday that our 2006 Prius needs a new battery pack. It has just under 115,000 miles. Replacing with new will cost just under $3400.00. Considering buying salvage and have also wrote to Toyota asking for help on part costs in an effort to save some money. Anyone have any feedback on either option? Thanks.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    176
    49
    Chesterfield, VA
    If it was mine, I would consider either a salvage battery or Re-Involt. E-bay has many for well under $1000. Re-Involt has gotten favorable reviews here.
    Before doing anything, however, I suggest describing the symptoms here and listing the diagnostic trouble codes the dealer pulled that lead them to believe it's the battery. Dealers unfortunately are sometimes wrong.
  3. BiffPa
    BiffPa New Member
    Pennsylvania
    Thanks for the reply, JimboK. This is what I can describe: master warning light, brake system warning light, hybrid system warning light and check engine light are all on. Battery charge graphic on multi indicator display shows more than half to fully charged all the time, but does not fill the entire display as in the past, the left side is not illuminated. When car is on, but in park, engine turns on and off repeatedly while normally it would be off. Service tech from yesterday is off today so I have not been able to get the diagnostic trouble codes. Does this tell you anything?
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,446
    38
    Santa Fe, NM
    +1 on the Re-Involt option.
    AutoBeYours.com (Southern Indiana) could also be helpful, for getting a salvage pack that is more likely to work than one out of a random junkyard. The main issue with a collision salvage pack is that the terminal voltage has to be high enough to turn the engine on, which may not be the case if it has been sitting for a long time. If it needs to be charged, then a DIY repair becomes much more difficult/dangerous. ZERO reason to buy a new one from Toyota, as the prismatic cells in Gen II have excellent longevity. Just like the engine, there will always be a plentiful supply of salvage battery packs, as the collision total-loss rate is higher than the failure rate.
  5. MJFrog
    MJFrog Active Member
    780
    257
    SE Michigan
    2011 Nissan LEAF
    How old is your 12v battery? If original or > 4yrs, I'd swap that out first and see if the symptoms go away.
  6. JimboPalmer
    JimboPalmer Friend to those who want no friends
    9,033
    2,908
    Greenwood MS USA
  7. JimN
    JimN Let the games begin!
    6,475
    735
    South Jersey
    If that was a NJ car I'd bet the dealer wouldn't recommend a new HV battery as it would be a warranty repair. What are the voltage readings from the 12v? The DTC should have been reported on the paperwork.
  8. JimboK
    2,817
    176
    49
    Chesterfield, VA
    No, not too much, although one of our technical experts-in-residence (not me) might be able to tell you more. The DTCs are the most important piece to the puzzle.
    Meanwhile, as MJFrog suggests, if your 12V battery is the original, you might consider replacing it. A marginal 12V can be the cause of a variety of strange symptoms in Prius. See this for more. I replaced mine after 4 years as a preventive maintenance measure.
  9. Hawaiiana
    Hawaiiana New Member
    I have an 07 Prius with 173000 miles...mostly from high mountain to plain driving in Colorado. 12 v started failing last year. Was in financially challenging times...and not sure I would hang on to vehicle due to possible move...so did not replace until this week. Was able to limp along for a year with one of those portable battery packs. Dealer who installed here told me that this is the highest mileage Prius they have seen to date. I now live in Hawaii....and due to gas prices am thrilled that I hung on to car. The only other items I have previously had to replace is water pump...which I think has been recognized as a design issue. I have never replaced the brakes and to date have only used 20% of the pads. SERIOUSLY. I am faithful about getting oil changes. I am one of those who ended up going down the road at 80 miles an hour unexpectedly...and yes i did have the rugged floor mats to which they attirbuted the problem. I will definitley get another Prius....probably second generation again...RELIABLE! Average 44-48 MPG.
  10. SteveLee
    SteveLee Active Member
    605
    126
    North Carolina
    I
    What was the resolution to this issue? Inquiring minds want to know. And it helps with the accumulation of knowledge on the subject.
  11. 3prongpaul
    3prongpaul 6 Gen1s, 3 Gen2s
    802
    478
    Boulder Hybids, Boulder, CO
    Where was BiffPa's car originally purchased? The 12-13 states which follow CA emission standards have 150k mile battery warranties, but it also depends on model year. For example, 2004 NJ cars had 100k mile battery warranty, 2005 and newer 150k.
