2006 Shuddering/Stuttering when Idle
Discussion in 'Gen 2 Prius Main Forum' started by phidler, Dec 20, 2010.
  1. phidler
    phidler New Member
    17
    SOCAL
    I've read a few posts related to this. I just purchased a used 2006 package 3 with 66500 miles on it. Drove it to work today and the car started sputtering/shuddering when i was accelerating onto the highway. The check engine line came on so I took it to the dealership. Turns out it was a bad sensor.
    When they fixed the bad sensor, the mechanic told me that its normal to feel a slight studdering when the gas engine kicks in or off which seems to be confirmed by other members here.
    This afternoon, I was idling at a light and I felt the sputtering/studdering again but it was much more pronounced. Thank goodness no check engine light came on.
    Any cause for concern? I don't think there is much the dealer can do if no service lights or warnings pop up.
  2. Patrick Wong
    18,198
    6,463
    What sensor was replaced?
    What DTC (diagnostic trouble code) was logged by your car?
    Since your area currently has heavy rain, perhaps your engine has a misfire due to water getting into the spark plug wells. Eventually that will trigger a DTC and the check engine light will appear.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    What the OP describes isn't normal. The start/stop shudder is pretty mild, often unnoticed, unless the engine is cold.
    Tom
  4. phidler
    phidler New Member
    17
    SOCAL
    Thanks Tom for the confirmation. I'm going back there Thurs morning to have them check this again.
  5. phidler
    phidler New Member
    17
    SOCAL
    I'll have to look at the paperwork for the codes.
    Is there any long term damage if water gets into the spark plug wells?
    Are any other SOCAL Prius drivers experiencing this?
  6. Patrick Wong
    18,198
    6,463
    I've seen at least one other poster from your area with a similar misfire problem yesterday.
    The only long term damage is that it is necessary to replace the spark igniters and spark plugs.
  7. phidler
    phidler New Member
    17
    SOCAL
    The airflow sensor was replaced.
    Codes that were logged were P0102 and P0113.
