1. Offline
    doogster Junior Member
    Start a Conversation
    Mar 12, 2012
    Your Vehicle Year:
    Hi. I bought my 1st 2008 Prius in Feb 2012. The first thing I really noticed was the "drag" (for lack of a better word) when coasting up to a light... no brake applied... no gas applied.... just... rolling. I noticed my 2008 would not roll as far as I was used to on a standard car. I assumed that was because of some sort of regeneration.
    Now... last week I bought another used Prius... a 2006. To my surprise, the 2006 seems to roll much further than the 2008!!! Almost like a regular car!
    So... what am I looking at here?
  2. Offline
    Britprius Senior Member
    Jun 14, 2010
    2,417
    516
    Herefordshire England
    Your Vehicle Year:
    Are the tyres the same make, type, and size as well as pressures. The other big difference to rolling resistance is wheel alignment front and rear. If tyres are different types please list tyers fitted.
    Brake binding will also cause the effect. Jack up the car and see if there is drag on any of the wheels. If the drag is that noticeable I would expect the 2006 to get better MPG's than the 2008.
  3. Offline
    Mar 12, 2012
    Your Vehicle Year:
    Not sure about the tire types... I'll check it out and post back later...
    I will say the 2006 is showing 55.3MPG on the display while the 2008 with more drag is getting only 51.5MPG
  4. Offline
    uart Senior Member
    Sep 7, 2009
    2,765
    476
    Australia
    Your Vehicle Year:
    Typically that's how my Prius feels in "B" mode. Any chance that there's some issue with the 2008 shifter and you're running it in "B" mode instead of "D". I'm sure you would have noticed so if this was the case.
    Just for comparison though, try running your 2006 in "B" mode and see how the feel compares.
  5. Offline
    12,333
    1,736
    Your Vehicle Year:
    you may want to jack up each wheel and see how it spins by hand.
  6. Offline
    Corwyn Energy Curmudgeon
    Mar 6, 2011
    1,884
    576
    Maine
    Your Vehicle Year:
    It is possible the 2008 has a different no-gas regeneration rate than the 2006. Try both with a tiny bit of gas pedal (to produce no arrows on the 'energy' screen), and see if they are the same under those circumstances.
  7. Offline
    12,333
    1,736
    Your Vehicle Year:
    i didn't notice any difference in feel between my 04 and 08, but the 08 did seem to get slightly better mileage?
    now the pip has noticeably more drag.
  8. Offline
    Aug 14, 2006
    18,140
    3,446
    Sacramento, CA.
    Your Vehicle Year:
    No doubt! My 2005 used to be able to glide/warp stealth for a full mile is started at 55mph. The 2012 is a joke in comparison. It can barely cover 1/4 of the distance. The 2012 gets significantly better mpg though. :)
  9. Offline
    69shovlhed Member
    May 13, 2012
    315
    65
    sterling, VA
    Your Vehicle Year:
    perhaps the rear brakes are adjusted too tight?
Share This Page
