2007 Electric Water Pump Conversion [Engine's]
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JoesMorgue, Apr 14, 2014.
  1. JoesMorgue
    JoesMorgue Junior Member
    61
    Outside Detroit, MI
    I'm driving a 2007 Prius [Gen II?] with 92k miles on her.
    I was told my belt has cracks and I should change it, and I've read about converting it to an electric pump.
    I've read the Prius C uses the same engine, and it has an electric pump. I THOUGHT I read about people putting them in the older models...
    Has anybody actually converted them?
    What do I need to know?
    Is there a controller board I need?
    How does it work? [Life compared to the belt driven model]
    Side effects? [Accel? Fuel economy? Anything else?]
    It it would last longer, I'm interested. HOPEFULLY, it will last longer!
    NortTexSalv04Prius likes this.
  2. JC91006
    16,470
    8,383
    Where did you read about converting it? I don't think anyone has done that on gen2
    SM-N900P ?
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Even if a conversion is possible, it would be terrible expensive......and might not last longer than 92K miles either.
    Consult an independent shop about a new belt.
    They usually can do it for about half the price, and often with exactly the same belt too.
  4. JoesMorgue
    61
    Outside Detroit, MI
    Does anybody here know anything about what the C's pump needs to run?
    It is more than just a power source, it would need to know when to turn off/on...
  5. bisco
    48,945
    i have never read about this being done, iirc. put a new belt on and enjoy, the gen II is a great car and the gen III is only marginally better. all the best!(y)
  6. JoesMorgue
    61
    Outside Detroit, MI
    I was HOPING to get positive comments about this...
    Can anyone give me some? :p
  7. JC91006
    16,470
    8,383
    You are on the GenII forum asking specifics on a Prius C. You should switch forums and HOPEFULLY find someone that's more knowledgeable about the C and what you are attempting to do with a GenII. I think someone had asked about doing this before and Patrick Wong had answered some of the questions you raised. End result I believe was it didn't happen.
  8. bisco
    48,945
    i am POSITIVE this cannot be done.:cool:
    m.wynn and jadziasman like this.
  9. Britprius
    Britprius Senior Member
    5,194
    1,912
    Herefordshire England
    I too have considered this conversion. However mainly because of the cost of the Prius C pump it is not cost effective. There are small problems to overcome as far as control is concerned, but nothing major. A simpler cheaper method would be to use a pancake motor driving the existing pump directly.
    Control can be as simple (turn on/off with the engine) or as complicated (speed control by temperature and time delay off as engine shuts down) as you wish. The pump could also run to pump heated coolant to provide cabin heat removing the need for the extra electric pump at present used for this.
    The reliability of the C pump is unknown, it could be a number of years to get reasonable figures.
    As an exercise I will do this conversion when I can find a C pump "possibly from salvage" at a realistic price.
    John (Britprius)
    NortTexSalv04Prius and JC91006 like this.
  10. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    WOW
  11. NortTexSalv04Prius
    915
    114
    FYI
    I have consider this modification as well and kinda got same posters. Britprius was the only true contribitor last time as well.....
    There are several quality DC electric circulation coolant pumps out there...The Prius C is a starting point..... Bosch/bmw /merced basic german mfg/design are of good quality and may work too.
    The Gen 3 prius went to a dc setup because less is more......the gen 2 during ice is constant move coolant which is not helpful with cold start/warmup cycle/
    My concerns are the opening created when removal of the belt pump style is removed, wiring, and cut in cut off cycles
    I am going toss this out here too has anyone consider a non 50/50 coolant......that is most coolants have a mix of water/silica/dye....... i am curious about evans coolant
    Home » Engine Cooling Systems
  12. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Yes fix the belt and forget the conversion to the gen III electric pump, in the long run you will save money.
  13. Britprius
    5,194
    1,912
    The gen3 pump will not fit the gen2 engine, but the C pump does as the C uses the same engine as the gen2, and as such is a direct replacement or gen2 mechanical pump. The only real modification being the control circuitry.
    John (Britprius)
  14. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    seems like a rube Goldberg mod to me; the mechanical pump does its job just fine, is inexpensive and very easy to replace with simple hand tools. the belt is also very easy to replace and no special tools are needed either. now, if someone does decide to do this, I'd love to read about it and see pix showing the installation, but I think its kinda pointless.
    m.wynn likes this.
  15. JoesMorgue
    61
    Outside Detroit, MI
    How hard would it be to do the circuitry?
  16. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
  17. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Still have to say why bother, putting on a new belt will be cheaper in the long run especially considering the limited advantages and the miles already on the car.
  18. bisco
    48,945
    my question is, what are the advantages? does it completely eliminate the belt? is there a payback for the time and trouble?
  19. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Might not be possible because the "circuitry" might involve one of the ECU modules, which would almost certainly be Prius c specific, and not interchangeable with the Gen2 Prius.
    SCH-I535
  20. vskid3
    vskid3 Active Member
    773
    228
    This seems like one of those things that is done for the fun of it. The risks vs rewards and potential cost don't really justify doing it to save money or to make it more reliable. If you want the cheapest, most reliable solution to keep your car running for many more miles, just place the belt and the water pump if needed. If you want a neat project, go ahead, sounds cool.
    m.wynn likes this.
